C Covina Member² Apr 25, 2006 #1 Currently, this software has capability to comment by /* comments ending with */. Can we have different options user selectable like the following: -- This is a Test Option 1 REM This is a Test Option 2 Thanks
patch Member³ Apr 26, 2006 #1 For the -- comments you can use my commentlines plug-in. You can find it at http://bar-solutions.com under Software/Plug-ins. For the REM option, I don't have a solution except just type it in . Regards, Patrick
