Stew Stryker
Subject isn't grammatically correct, but it'll be great for a keyword search later!
My code invariably takes up multiple screens (that is, more lines than is viewable at once on my monitor). If I try to select a block that's spread over more than the current screen by click and drag, and then I move the mouse pointer above the window more than a pixel or two, it scrolls super-fast and ends up at the top or bottom of the file. There doesn't seem to be any option to control this. I normally have my other Windows apps set to NOT smooth scroll, but this scrolls so fast I can't control it.
Is it just me, or what?
I'm using the latest rev 6.0.2.880
Stew
Stew
