'EAccessViolation' in module URLMON.DLL
hemi
Hi
I am receiving 'EAccessViolation' in module URLMON.DLL error when i try to run Reports in PLSQL Developer, from the Reports menu. Below is the error message from plsqldev.log.
---------------------------4/30/2010 10:46:02 AM---------------------------
Exception 'EAccessViolation' in module URLMON.DLL at 000027B4
Access violation at address 7E1E37B4 in module 'URLMON.DLL'. Write of address 00000000
Call stack:
:7E1E37B4 [URLMON.DLL]
:7E1E9BF6 [URLMON.DLL]
:08B402D3 [ieframe.dll]
:004066EF [plsqldev.exe] (system.pas, line 13370)
:00402F5F [plsqldev.exe] (system.pas, line 2526)
:00406443 [plsqldev.exe] (system.pas, line 13024)
:00405F9D [plsqldev.exe] (system.pas, line 12103)
:7E4188D1 [user32.dll]
:7E4188DA [user32.dll]
:7E4194BE [user32.dll]
:7E428E0D [user32.dll]
:00426B78 [plsqldev.exe]
:0046D3C6 [plsqldev.exe] (ComCtrls.pas, line 5531)
:7E42C228 [user32.dll]
:7E418BD9 [user32.dll]
:7E42C23C [user32.dll]
Recursive call (2 times):
:7E42C1E9 [user32.dll]
:7E418734 [user32.dll]
:7E41885A [user32.dll]
:7E41882A [user32.dll]
:7E42A013 [user32.dll]
:00423B9B [plsqldev.exe]
:77F18234 [GDI32.dll]
:0049FBAC [plsqldev.exe]
:77F18BBF [GDI32.dll]
:7E429009 [user32.dll]
:0049FA23 [plsqldev.exe]
:0049FE24 [plsqldev.exe]
:0049C52F [plsqldev.exe]
:004A1B7A [plsqldev.exe]
:0049C75F [plsqldev.exe]
:00405118 [plsqldev.exe] (system.pas, line 8831)
:7C910222 [ntdll.dll]
:004B7336 [plsqldev.exe]
:7C911086 [ntdll.dll]
:7C9101DB [ntdll.dll]
:7C91019B [ntdll.dll]
:7E44F980 [user32.dll]
:0049F7C0 [plsqldev.exe]
:004B87A4 [plsqldev.exe]
:00425B75 [plsqldev.exe]
:77F16BF2 [GDI32.dll]
:77F16BDC [GDI32.dll]
:7C910041 [ntdll.dll]
:7C91005D [ntdll.dll]
:7E428EAB [user32.dll]
:7E428EEC [user32.dll]
:7C910435 [ntdll.dll]
:7C91043E [ntdll.dll]
:7C914388 [ntdll.dll]
:7C910460 [ntdll.dll]
:7C914049 [ntdll.dll]
:7C91403C [ntdll.dll]
:7C9100B8 [ntdll.dll]
:7C9020F5 [ntdll.dll]
:7C9115F9 [ntdll.dll]
:7C9114D6 [ntdll.dll]
:7C911514 [ntdll.dll]
:7C9114EA [ntdll.dll]
:7C9115C6 [ntdll.dll]
:7C9142AF [ntdll.dll]
:7C91162C [ntdll.dll]
:7C80EF6C [kernel32.dll]
:7C80EE45 [kernel32.dll]
:7C80EE58 [kernel32.dll]
:7C80DFDF [kernel32.dll]
Main Thread ID = 00000F70, Current Thread ID = 00000F70
Registers:
EAX = 001AE9E8 CS = 001B EIP = 7E1E37B4 Flags = 00210246
EBX = 00000000 SS = 0023 ESP = 001AE990 EBP = 001AE99C
ECX = 00004082 DS = 0023 ESI = 00000000 FS = 003B
EDX = 0000004E ES = 0023 EDI = 00000001 GS = 0000
Code at CS:EIP
89 33 E8 C7 F1 FF FF 85 C0 0F 84 D3 37 02 00 39
Stack:
0886A40C 00000001 00000000 001AE9B4 7E1E9BF6
00000000 00000000 7C91005D 00404E05 087C0858
0043890B 00000002 00000000 00000000 015CA890
7C91005D FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
Additional info:
PL/SQL Developer
Version 7.0.3.1123 (MBCS)
01.25238 - 5 user license
Windows XP version 6.0 (build 2600) Service Pack 3
Physical memory : 2,097,152 kB (1,888,232 available)
Virtual memory : 2,097,024 kB (1,924,032 available)
Parameters
Preferences
Session mode: Multi
OCI Library:
Use OCI7: False
Preference Files
C:\Program Files\PLSQL Developer\Preferences\Default\Default.ini
C:\Program Files\PLSQL Developer\Preferences\SandhuH\default.ini
Plug-Ins
*PL/SQL Documentation (plsqldoc) (C:\Program Files\PLSQL Developer\PlugIns\plsqldoc.dll)
(* is Active)
Aliases
Homes
DLLs
c:\Oracle\instantclient10_1\oci.dll
TNS File
c:\Oracle\instantclient10_1\tnsnames.ora
Using
Home:
DLL: c:\Oracle\instantclient10_1\oci.dll
OCI: version 9.2
Oracle9i Enterprise Edition Release 9.2.0.6.0
Character size: 1 byte(s)
Windows
*Command Window - New
Report Window - ReportName.rep
Program Window - View source of package body Package_name
Program Window - View source of package Package_name
Can you go to Tools > Preferences > User Interface / Options and enable the "Use Internal HTML Viewer" option? Restart PL/SQL Developer and check if this has a positive effect on the issue.
