Claus Pedersen
I am performing a long-running find-and-replace operation in a file.
I shift to another program, but the find-and-replace is stuck, it stays on top of other programs and can not be minimised. Only when PLD has finished the operation, the dialog is hidden together with the PLD main window (as normal).
There a three ways to improve this:
The good: make major improvements to the PLD find-and-replace engine. Several minutes to perform a couple of thousand find-and-replace operations in a file with e.g. 10,000 lines is not good enough for a simple text editor.
The bad: make a busy find-and-replace dialog hide together with the rest of the main IDE window when using other programs.
And the ugly: kill PLD using the task manager.
I am using version 11.0.5.1790, 64 bit
