Hi Marco,
Attached is the debug output. Thanks for the help on this!
PL/SQL Developer
Version 9.0.6.1665
Physical memory : 4,194,304 kB (2,354,832 available)
Virtual memory : 2,097,024 kB (1,960,376 available)
Parameters
C:\Program Files (x86)\PLSQL Developer\plsqldev.exe
DebugSQL
Preferences
Session mode: Multi
OCI Library:
Use OCI7: False
Preference Files
Plug-Ins
10/5/2012 8:44:54 AM Application started
10/5/2012 8:44:54 AM InitPreferences
10/5/2012 8:44:54 AM Load C:\Users\csauer\AppData\Roaming\PLSQL Developer\Preferences\default = 0
10/5/2012 8:44:54 AM PreferenceSet.Load C:\Users\csauer\AppData\Roaming\PLSQL Developer\Preferences\default\Default.ini
10/5/2012 8:44:54 AM PreferenceSet.Load OK
10/5/2012 8:44:54 AM Determine LocalPrefPath
10/5/2012 8:44:54 AM [1]: C:\Users\csauer\AppData\Roaming\PLSQL Developer\Preferences
10/5/2012 8:44:54 AM LocalPrefPath: C:\Users\csauer\AppData\Roaming\PLSQL Developer\Preferences\csauer
10/5/2012 8:44:54 AM Load C:\Users\csauer\AppData\Roaming\PLSQL Developer\Preferences\csauer = 0
10/5/2012 8:44:54 AM PreferenceSet.Load C:\Users\csauer\AppData\Roaming\PLSQL Developer\Preferences\csauer\default.ini
10/5/2012 8:44:54 AM PreferenceSet.Load C:\Users\csauer\AppData\Roaming\PLSQL Developer\Preferences\csauer\user.prefs
10/5/2012 8:44:54 AM InitPreferences end
10/5/2012 8:44:54 AM SortPreferenceSets
10/5/2012 8:44:54 AM - Default csauer
10/5/2012 8:44:54 AM - System Default
10/5/2012 8:44:54 AM DoUpdateChildList
10/5/2012 8:44:54 AM FindPassword starts for epmv3@HPCRS
10/5/2012 8:44:54 AM Check current connections...
10/5/2012 8:44:54 AM Checking epmv3@ORACLE1...
10/5/2012 8:44:54 AM Checking epmv3pro@ORACLE1...
10/5/2012 8:44:54 AM Checking claims@oracle1...
10/5/2012 8:44:54 AM Checking x12@oracle1...
10/5/2012 8:44:54 AM Checking sys@HPCRS...
10/5/2012 8:44:54 AM Checking vim@oracle1...
10/5/2012 8:44:54 AM Checking citrus@ORACLE1...
10/5/2012 8:44:54 AM Checking plvision@ORACLE1...
10/5/2012 8:44:54 AM Checking sys@oracle1...
10/5/2012 8:44:54 AM Check connection definitions...
10/5/2012 8:44:54 AM FindPassword ends for epmv3@HPCRS, no result
10/5/2012 8:44:54 AM FindPassword starts for epmv2d@HPCRS
10/5/2012 8:44:54 AM Checking epmv3@HPCRS...
10/5/2012 8:44:54 AM FindPassword ends for epmv2d@HPCRS, no result
10/5/2012 8:44:54 AM FindPassword starts for citrus@apollo
10/5/2012 8:44:54 AM Checking epmv2d@HPCRS...
10/5/2012 8:44:54 AM FindPassword ends for citrus@apollo, no result
10/5/2012 8:44:54 AM FindPassword starts for citrus@hpcrs
10/5/2012 8:44:54 AM Checking citrus@apollo...
10/5/2012 8:44:54 AM FindPassword ends for citrus@hpcrs, no result
10/5/2012 8:44:54 AM FindPassword starts for x12@apollo
10/5/2012 8:44:54 AM Checking citrus@hpcrs...
10/5/2012 8:44:54 AM Checking claims@zeus...
10/5/2012 8:44:54 AM FindPassword ends for x12@apollo, no result
10/5/2012 8:44:54 AM FindPassword starts for sys@apollox
10/5/2012 8:44:54 AM Checking x12@apollo...
10/5/2012 8:44:54 AM FindPassword ends for sys@apollox, no result
10/5/2012 8:44:54 AM FindPassword starts for sys@ZEUS
10/5/2012 8:44:54 AM Checking sys@apollox...
10/5/2012 8:44:54 AM Checking citrus@apollox...
10/5/2012 8:44:54 AM FindPassword ends for sys@ZEUS, no result
10/5/2012 8:44:54 AM FindPassword starts for vim@apOLLO
10/5/2012 8:44:54 AM Checking sys@ZEUS...
10/5/2012 8:44:54 AM FindPassword ends for vim@apOLLO, no result
10/5/2012 8:44:54 AM FindPassword starts for vim@ODEN
10/5/2012 8:44:54 AM Checking vim@apOLLO...
10/5/2012 8:44:54 AM FindPassword ends for vim@ODEN, no result
10/5/2012 8:44:54 AM FindPassword starts for vim@hPCRS
10/5/2012 8:44:54 AM Checking vim@ODEN...
10/5/2012 8:44:54 AM FindPassword ends for vim@hPCRS, no result
10/5/2012 8:44:54 AM FindPassword starts for vim@zEUS
10/5/2012 8:44:54 AM Checking vim@hPCRS...
10/5/2012 8:44:54 AM FindPassword ends for vim@zEUS, no result
10/5/2012 8:44:54 AM pfReadRegistry(PL/SQL Developer\Shell\Open\Command, )
10/5/2012 8:44:55 AM ReadString OK
10/5/2012 8:44:55 AM pfReadRegistry: "C:\Program Files (x86)\PLSQL Developer\PLSQLDev.exe" "%1"
10/5/2012 8:44:55 AM LoadPreferences
10/5/2012 8:44:55 AM LoadPreferences searching for default
10/5/2012 8:44:55 AM C:\Users\csauer\AppData\Roaming\PLSQL Developer\Preferences\csauer\default.ini
10/5/2012 8:44:55 AM LoadPreferences NewPref := nil
10/5/2012 8:44:55 AM LoadPreferences Reading preferences
10/5/2012 8:44:55 AM LoadPreferences ReadPosition
10/5/2012 8:44:55 AM LoadPreferences ToolsBrowserItemClick(nil)
10/5/2012 8:44:55 AM LoadPreferences CreateBrowserFilters...
10/5/2012 8:44:55 AM LoadPreferences Files
10/5/2012 8:44:55 AM LoadPreferences Buttons
10/5/2012 8:44:55 AM LoadPreferences Printer
10/5/2012 8:44:55 AM LoadPreferences FileBrowserFolders
10/5/2012 8:44:55 AM LoadPreferences Connections
10/5/2012 8:44:55 AM LoadPreferences BrowserFolders
10/5/2012 8:44:55 AM LoadPreferences end
10/5/2012 8:44:55 AM MacroLibFilename: C:\Program Files (x86)\PLSQL Developer\Macro\csauer.emlib
10/5/2012 8:44:55 AM Logging on..
10/5/2012 8:44:55 AM Creating new session
10/5/2012 8:44:55 AM Initializing new session
10/5/2012 8:44:55 AM Setting new session parameters
10/5/2012 8:44:55 AM Setting logon session
10/5/2012 8:44:55 AM OCI Initialization starts
10/5/2012 8:44:55 AM OCI Initialization done
10/5/2012 8:44:55 AM OracleHomeKey: SOFTWARE\ORACLE\KEY_OraClient11g_home1
OracleHomeDir: D:\app\product\11.2.0\client_1
Found: oci.dll
Using: D:\app\product\11.2.0\client_1\bin\oci.dll
10/5/2012 8:44:55 AM Logon2 starting
10/5/2012 8:44:55 AM Logon2.Execute starts
10/5/2012 8:44:55 AM TOracleSession $05D8C140 Start Session.LogOn as epmv3@ORACLE1
10/5/2012 8:44:59 AM TOracleQuery Query Start Query.Execute
10/5/2012 8:44:59 AM TOracleQuery Query End (1 record processed)
Duration = 0.202
10/5/2012 8:44:59 AM TOracleSession $05D8C140 End
Duration = 3.791
10/5/2012 8:44:59 AM Logon2.Execute done
10/5/2012 8:44:59 AM Logon2 done
SQL = select * from v$version
10/5/2012 8:44:59 AM TOracleQuery Query End (5 records processed)
Duration = 0.203
10/5/2012 8:44:59 AM TOracleQuery $05D4C4A0 Start Query.Execute
sys.plsqldev_authorization
10/5/2012 8:44:59 AM TOracleQuery $05D4C4A0 End
Duration = 0.219
10/5/2012 8:44:59 AM LogonHistorySave start
10/5/2012 8:44:59 AM ChangeUserPref LogonHistory,
10/5/2012 8:44:59 AM ChangeUserPref DSA,
10/5/2012 8:44:59 AM ChangeUserPref end
10/5/2012 8:44:59 AM ChangeUserPref ColumnAssociations,
10/5/2012 8:44:59 AM ChangeUserPref ImportAssociations,
10/5/2012 8:44:59 AM ChangeUserPref BrowserFilters,
10/5/2012 8:44:59 AM ChangeUserPref FileBrowserFolders,
10/5/2012 8:44:59 AM ChangeUserPref Connections,
10/5/2012 8:44:59 AM ChangeUserPref BrowserFolders,
10/5/2012 8:44:59 AM ChangeUserPref SessionQueries,
10/5/2012 8:44:59 AM ChangeUserPref ExternalTools,
10/5/2012 8:44:59 AM ChangeUserPref Documents,
10/5/2012 8:44:59 AM ChangeUserPref Reports,
10/5/2012 8:44:59 AM ChangeUserPref CurrentConnections,
10/5/2012 8:44:59 AM PreferenceSet.Save
10/5/2012 8:44:59 AM PreferenceSet Filename = C:\Users\csauer\AppData\Roaming\PLSQL Developer\Preferences\csauer\user.prefs
10/5/2012 8:44:59 AM PreferenceSet AltFile = user.prefs
10/5/2012 8:44:59 AM PreferenceSet.Save end
10/5/2012 8:44:59 AM LogonHistorySave end
10/5/2012 8:44:59 AM FormCreate Logon.Executed -1
10/5/2012 8:44:59 AM FormCreate SessionChanged
10/5/2012 8:45:00 AM TOracleQuery Query End (5 records processed)
Duration = 0.203
10/5/2012 8:45:00 AM TOracleQuery $05D4C340 Start Query.Execute
10/5/2012 8:45:00 AM TOracleQuery $05D4C340 End (1 record processed)
Duration = 0.203
10/5/2012 8:45:00 AM SessionChanged SetDBAViews
10/5/2012 8:45:00 AM TOracleQuery $05D4C340 End (0 records processed)
Duration = 0.203
Duration = 0.203
10/5/2012 8:45:00 AM TOracleQuery BytesPerCharacterQuery Start Query.Execute
10/5/2012 8:45:00 AM TOracleQuery BytesPerCharacterQuery End (1 record processed)
Duration = 0.203
10/5/2012 8:45:01 AM TOracleQuery BytesPerCharacterQuery End (1 record processed)
Duration = 0.203
10/5/2012 8:45:01 AM SessionChanged Authorizations.Load
10/5/2012 8:45:01 AM SessionChanged EnableAuthorizedMenus
10/5/2012 8:45:01 AM WindowAllowed(1)
10/5/2012 8:45:01 AM WindowAllowed done
10/5/2012 8:45:01 AM ExecuteConnectScript starts
10/5/2012 8:45:01 AM TOracleQuery $05D4C340 Start Query.Execute
SQL = alter session set plsql_optimize_level = 2
10/5/2012 8:45:01 AM TOracleQuery $05D4C340 End
Duration = 0.109
SQL = alter session set plsql_code_type = native
Duration = 0.109
SQL = alter session set plscope_settings = 'identifiers:none'
Duration = 0.109
10/5/2012 8:45:01 AM ExecuteConnectScript ends
10/5/2012 8:45:01 AM SetSessionAction starts: Primary Session
SQL = select null from dual
10/5/2012 8:45:01 AM TOracleQuery $05D4C340 End (1 record processed)
Duration = 0.203
:ACTION = Primary Session
Duration = 0.109
10/5/2012 8:45:01 AM SetSessionAction ends
10/5/2012 8:45:01 AM SessionChanged LoadRecentObjects
10/5/2012 8:45:01 AM SessionChanged Notify children
10/5/2012 8:45:01 AM SessionChanged Logoff secondary sessions
10/5/2012 8:45:01 AM SessionChanged EnableChildFunctions
Found: oci.dll
10/5/2012 8:45:01 AM Lock
10/5/2012 8:45:01 AM UnLock
10/5/2012 8:45:03 AM SortPreferenceSets
10/5/2012 8:45:03 AM - Default csauer
10/5/2012 8:45:03 AM - System Default
10/5/2012 8:45:03 AM TOracleQuery $05D4C340 Start Query.Execute
10/5/2012 8:45:04 AM TOracleQuery $05D4C340 End (0 records processed)
Duration = 0.203
10/5/2012 8:45:04 AM TOracleQuery $05D4C340 Start Query.Execute
Duration = 0.203
10/5/2012 8:45:04 AM Lock
10/5/2012 8:45:04 AM UnLock
10/5/2012 8:45:04 AM DoUpdateChildList
10/5/2012 8:45:04 AM FormActivate start
10/5/2012 8:45:04 AM FormActivate end
10/5/2012 8:45:04 AM WMUpdatePopups starts
10/5/2012 8:45:04 AM Adding new connection
10/5/2012 8:45:04 AM Username = epmv3
10/5/2012 8:45:04 AM Database = ORACLE1
10/5/2012 8:45:05 AM Username = epmv3pro
10/5/2012 8:45:05 AM Database = ORACLE1
10/5/2012 8:45:05 AM Adding new connection
10/5/2012 8:45:05 AM Username = claims
10/5/2012 8:45:05 AM Database = oracle1
10/5/2012 8:45:05 AM Username = x12
10/5/2012 8:45:05 AM Username = sys
10/5/2012 8:45:05 AM Database = HPCRS
10/5/2012 8:45:05 AM Username = vim
10/5/2012 8:45:05 AM Username = citrus
10/5/2012 8:45:05 AM Username = plvision
10/5/2012 8:45:05 AM Username = epmv2d
10/5/2012 8:45:05 AM Database = apollo
10/5/2012 8:45:05 AM Database = hpcrs
10/5/2012 8:45:05 AM Database = zeus
10/5/2012 8:45:05 AM Database = apollox
10/5/2012 8:45:05 AM Database = ZEUS
10/5/2012 8:45:05 AM Database = apOLLO
10/5/2012 8:45:05 AM Database = ODEN
10/5/2012 8:45:05 AM Database = hPCRS
10/5/2012 8:45:05 AM Database = zEUS
10/5/2012 8:45:05 AM Database = APOLLOX
10/5/2012 8:45:05 AM Username = system
10/5/2012 8:45:05 AM Database = orACLE1
10/5/2012 8:45:05 AM LoadDesktop starts
10/5/2012 8:45:05 AM LoadDesktop Window = 4
10/5/2012 8:45:05 AM WindowAllowed(4)
10/5/2012 8:45:05 AM WindowAllowed done
10/5/2012 8:45:05 AM Create TCommandForm Start
10/5/2012 8:45:05 AM Create TCommandForm Inherited
10/5/2012 8:45:05 AM Create TCommandForm SetupMainFont
10/5/2012 8:45:05 AM Create TCommandForm Activate
10/5/2012 8:45:05 AM Create TCommandForm Activate done
10/5/2012 8:45:05 AM Create TCommandForm UpdateWindowList
10/5/2012 8:45:05 AM Create TCommandForm Positioning
10/5/2012 8:45:05 AM Create TCommandForm Finished
10/5/2012 8:45:05 AM Lock
10/5/2012 8:45:05 AM UnLock
10/5/2012 8:45:05 AM SetConnected starts
10/5/2012 8:45:05 AM SetConnected: Connect starts
10/5/2012 8:45:05 AM TOracleSession $05D8D640 Start Session.LogOn as epmv3@ORACLE1
10/5/2012 8:45:06 AM TOracleQuery Query Start Query.Execute
10/5/2012 8:45:06 AM TOracleQuery Query End (1 record processed)
Duration = 0.203
10/5/2012 8:45:06 AM TOracleSession $05D8D640 End
Duration = 1.295
10/5/2012 8:45:06 AM SetConnected: (Dis)connect ends
10/5/2012 8:45:06 AM SetSessionAction starts: Command Window - New
10/5/2012 8:45:06 AM TOracleQuery $05D4C1E0 Start Query.Execute
10/5/2012 8:45:06 AM TOracleQuery $05D4C1E0 End (1 record processed)
Duration = 0.202
10/5/2012 8:45:06 AM TOracleQuery BytesPerCharacterQuery Start Query.Execute
10/5/2012 8:45:07 AM TOracleQuery BytesPerCharacterQuery End (1 record processed)
Duration = 0.203
10/5/2012 8:45:07 AM TOracleQuery BytesPerCharacterQuery Start Query.Execute
Duration = 0.218
10/5/2012 8:45:07 AM TOracleQuery $05D4C1E0 Start Query.Execute
:ACTION = Command Window - New
10/5/2012 8:45:07 AM TOracleQuery $05D4C1E0 End
Duration = 0.094
10/5/2012 8:45:07 AM SetSessionAction ends
10/5/2012 8:45:07 AM ExecuteConnectScript starts
Duration = 0.109
Duration = 0.109
Duration = 0.11
10/5/2012 8:45:07 AM ExecuteConnectScript ends
10/5/2012 8:45:07 AM TOracleQuery $05D4C1E0 End (1 record processed)
Duration = 0.202
10/5/2012 8:45:07 AM TOracleQuery Query Start Query.Execute
10/5/2012 8:45:08 AM TOracleQuery Query End (5 records processed)
Duration = 0.203
10/5/2012 8:45:08 AM AddScript(login.sql)
10/5/2012 8:45:08 AM 1 Filename=login.sql
10/5/2012 8:45:08 AM CheckFile(C:\Program Files (x86)\PLSQL Developer, login.sql, sql)
10/5/2012 8:45:08 AM CheckFile (0) C:\Program Files (x86)\PLSQL Developer\login.sql
10/5/2012 8:45:08 AM 2 Filename=C:\Program Files (x86)\PLSQL Developer\login.sql
10/5/2012 8:45:08 AM Lock
10/5/2012 8:45:08 AM UnLock
10/5/2012 8:45:08 AM LoadDesktop ChildListIndex = 2
10/5/2012 8:45:08 AM LoadDesktop WindowName =
10/5/2012 8:45:08 AM SetSessionAction starts: Primary Session
10/5/2012 8:45:08 AM TOracleQuery $05D4C1E0 Start Query.Execute
10/5/2012 8:45:08 AM TOracleQuery $05D4C1E0 End (1 record processed)
Duration = 0.203
Duration = 0.093
10/5/2012 8:45:08 AM SetSessionAction ends
10/5/2012 8:45:08 AM LoadDesktop Window = 3
10/5/2012 8:45:08 AM WindowAllowed(3)
10/5/2012 8:45:08 AM WindowAllowed done
10/5/2012 8:45:08 AM Create TProcEditForm Start
10/5/2012 8:45:08 AM Create TProcEditForm Inherited
10/5/2012 8:45:08 AM AddNavigationBookmark starts
10/5/2012 8:45:08 AM Create TProcEditForm SetupMainFont
10/5/2012 8:45:08 AM Create TProcEditForm Activate
10/5/2012 8:45:08 AM Create TProcEditForm Activate done
10/5/2012 8:45:08 AM Create TProcEditForm UpdateWindowList
10/5/2012 8:45:08 AM Create TProcEditForm Positioning
10/5/2012 8:45:08 AM Create TProcEditForm Finished
10/5/2012 8:45:08 AM LoadDesktop ChildListIndex = 4
10/5/2012 8:45:08 AM TOracleQuery $05D4C080 Start Query.Execute
SQL = select text from sys.all_source
where owner =
wner
and name = :name
and type = :type
order by line
:OWNER = EPMV3
:NAME = SSPPATIENTACCOUNT_EPM
:TYPE = PROCEDURE
10/5/2012 8:45:08 AM TOracleQuery $05D4C080 End (100 records processed)
Duration = 0.203
10/5/2012 8:45:08 AM TOracleQuery $05D4C080 Start Query.Next for up to 100 records
10/5/2012 8:45:09 AM TOracleQuery $05D4C080 End (94 records processed)
Duration = 0.109
10/5/2012 8:45:09 AM TOracleQuery $05D4C080 Start Query.Execute
SQL = select *
from sys.all_errors
where name = :name and type = :type and owner =
wner
order by sequence
:TYPE = PROCEDURE
:OWNER = EPMV3
10/5/2012 8:45:09 AM TOracleQuery $05D4C080 End (0 records processed)
Duration = 0.203
10/5/2012 8:45:09 AM ProcEditForm.GetTabNames
10/5/2012 8:45:09 AM + SSPPATIENTACCOUNT_EPM
10/5/2012 8:45:09 AM ProcEditForm.GetTabNames done
10/5/2012 8:45:09 AM Lock
10/5/2012 8:45:09 AM UnLock
10/5/2012 8:45:09 AM TOracleQuery Query Start Query.Execute
:ID = Null
10/5/2012 8:45:09 AM TOracleQuery Query End
Duration = 0.094
10/5/2012 8:45:09 AM NavigationBookmarks.EnableButtons(Rebuild)
10/5/2012 8:45:09 AM NavigationBookmarks: Backward=0, Forward=0
10/5/2012 8:45:09 AM UpdateContents(Clear)
10/5/2012 8:45:09 AM Source = CREATE OR REPLACE PROCEDURE "SSPPATIENTACCOUNT_EPM" (v_ClientID IN VARCHAR2 DEFAULT NULL,
10/5/2012 8:45:09 AM UpdatingContents: Thread Started
10/5/2012 8:45:09 AM ContentsThread: Execute
10/5/2012 8:45:09 AM ContentsThread: Analyze
10/5/2012 8:45:09 AM ContentsThread: Valid
10/5/2012 8:45:09 AM ContentsThread: Suspend started
10/5/2012 8:45:09 AM LoadDesktop WindowName =
10/5/2012 8:45:09 AM SetSessionAction starts: Primary Session
10/5/2012 8:45:09 AM TOracleQuery $05D4C080 End (1 record processed)
Duration = 0.203
Duration = 0.109
10/5/2012 8:45:09 AM SetSessionAction ends
10/5/2012 8:45:09 AM LoadDesktop Window = 3
10/5/2012 8:45:09 AM WindowAllowed(3)
10/5/2012 8:45:09 AM WindowAllowed done
10/5/2012 8:45:09 AM Create TProcEditForm Start
10/5/2012 8:45:09 AM Create TProcEditForm Inherited
10/5/2012 8:45:10 AM Lock
10/5/2012 8:45:10 AM UnLock
10/5/2012 8:45:10 AM AddNavigationBookmark starts
10/5/2012 8:45:10 AM Create TProcEditForm SetupMainFont
10/5/2012 8:45:10 AM Create TProcEditForm Activate
10/5/2012 8:45:10 AM Create TProcEditForm Activate done
10/5/2012 8:45:10 AM Create TProcEditForm UpdateWindowList
10/5/2012 8:45:10 AM Create TProcEditForm Positioning
10/5/2012 8:45:10 AM Create TProcEditForm Finished
10/5/2012 8:45:10 AM LoadDesktop ChildListIndex = 3
10/5/2012 8:45:10 AM TOracleSession $08C85830 Start Session.LogOn as epmv3pro@ORACLE1
10/5/2012 8:45:11 AM TOracleQuery Query Start Query.Execute
10/5/2012 8:45:11 AM TOracleQuery Query End (1 record processed)
Duration = 0.203
10/5/2012 8:45:11 AM TOracleSession $08C85830 End
Duration = 1.576
10/5/2012 8:45:11 AM SetSessionAction starts: Primary Session
10/5/2012 8:45:11 AM TOracleQuery $05D4BDC0 Start Query.Execute
10/5/2012 8:45:11 AM TOracleQuery $05D4BDC0 End (1 record processed)
Duration = 0.202
10/5/2012 8:45:11 AM TOracleQuery BytesPerCharacterQuery Start Query.Execute
10/5/2012 8:45:12 AM TOracleQuery BytesPerCharacterQuery End (1 record processed)
Duration = 0.203
10/5/2012 8:45:12 AM TOracleQuery BytesPerCharacterQuery Start Query.Execute
Duration = 0.203
10/5/2012 8:45:12 AM TOracleQuery $05D4BDC0 Start Query.Execute
10/5/2012 8:45:12 AM TOracleQuery $05D4BDC0 End
Duration = 0.094
10/5/2012 8:45:12 AM SetSessionAction ends
10/5/2012 8:45:12 AM TOracleQuery Query Start Query.Execute
10/5/2012 8:45:12 AM TOracleQuery Query End (5 records processed)
Duration = 0.203
Duration = 0.219
10/5/2012 8:45:13 AM TOracleQuery $05D4BDC0 End (1 record processed)
Duration = 0.203
10/5/2012 8:45:13 AM Lock
10/5/2012 8:45:13 AM UnLock
10/5/2012 8:45:13 AM TOracleQuery $05D4BDC0 Start Query.Execute
where owner =
wner
and name = :name
and type = :type
order by line
:OWNER = EPMV3PRO
:NAME = BILLINGPKG
:TYPE = PACKAGE
10/5/2012 8:45:13 AM TOracleQuery $05D4BDC0 End (100 records processed)
Duration = 0.203
10/5/2012 8:45:13 AM TOracleQuery $05D4BDC0 Start Query.Next for up to 100 records
10/5/2012 8:45:13 AM TOracleQuery $05D4BDC0 End (7 records processed)
Duration = 0.094
SQL = select *
from sys.all_errors
wner
order by sequence
:NAME = BILLINGPKG
:TYPE = PACKAGE
:OWNER = EPMV3PRO
10/5/2012 8:45:13 AM TOracleQuery $05D4BDC0 End (0 records processed)
Duration = 0.203
10/5/2012 8:45:13 AM ProcEditForm.GetTabNames
10/5/2012 8:45:13 AM + BILLINGPKG
10/5/2012 8:45:13 AM ProcEditForm.GetTabNames done
10/5/2012 8:45:13 AM TOracleQuery Query Start Query.Execute
:ID = Null
10/5/2012 8:45:13 AM TOracleQuery Query End
Duration = 0.094
10/5/2012 8:45:13 AM NavigationBookmarks.EnableButtons(Rebuild)
10/5/2012 8:45:13 AM NavigationBookmarks: Backward=0, Forward=0
10/5/2012 8:45:13 AM UpdateContents(Clear)
10/5/2012 8:45:13 AM Source = CREATE OR REPLACE PACKAGE BILLINGPKG
10/5/2012 8:45:13 AM UpdatingContents: Thread Started
10/5/2012 8:45:13 AM ContentsThread: Execute
10/5/2012 8:45:13 AM ContentsThread: Analyze
10/5/2012 8:45:13 AM ContentsThread: Valid
10/5/2012 8:45:14 AM ContentsThread: Suspend started
10/5/2012 8:45:14 AM TOracleQuery $05D4BDC0 Start Query.Execute
SQL = select * from sys.all_objects
where object_type =
bject_type
and owner =
bject_owner
and object_name =
bject_name
and :sub_object is null
:OBJECT_TYPE = PACKAGE BODY
:OBJECT_OWNER = EPMV3PRO
:OBJECT_NAME = BILLINGPKG
:SUB_OBJECT = Null
10/5/2012 8:45:14 AM TOracleQuery $05D4BDC0 End (1 record processed)
Duration = 0.202
where owner =
wner
and name = :name
and type = :type
order by line
:OWNER = EPMV3PRO
:NAME = BILLINGPKG
:TYPE = PACKAGE BODY
10/5/2012 8:45:14 AM TOracleQuery $05D4BDC0 End (100 records processed)
Duration = 0.218
10/5/2012 8:45:14 AM TOracleQuery $05D4BDC0 Start Query.Next for up to 100 records
Duration = 0.094
Duration = 0.094
Duration = 0.094
Duration = 0.109
10/5/2012 8:45:15 AM TOracleQuery $05D4BDC0 End (100 records processed)
Duration = 0.109
10/5/2012 8:45:15 AM TOracleQuery $05D4BDC0 Start Query.Next for up to 100 records
Duration = 0.093
Duration = 0.093
Duration = 0.109
Duration = 0.109
Duration = 0.11
Duration = 0.094
Duration = 0.094
Duration = 0.109
10/5/2012 8:45:16 AM TOracleQuery $05D4BDC0 End (100 records processed)
Duration = 0.109
10/5/2012 8:45:16 AM TOracleQuery $05D4BDC0 Start Query.Next for up to 100 records
Duration = 0.109
Duration = 0.109
Duration = 0.109
Duration = 0.109
Duration = 0.094
Duration = 0.109
Duration = 0.11
Duration = 0.109
10/5/2012 8:45:17 AM TOracleQuery $05D4BDC0 End (100 records processed)
Duration = 0.109
10/5/2012 8:45:17 AM TOracleQuery $05D4BDC0 Start Query.Next for up to 100 records
10/5/2012 8:45:17 AM TOracleQuery $05D4BDC0 End (43 records processed)
Duration = 0.109
10/5/2012 8:45:17 AM TOracleQuery $05D4BDC0 Start Query.Execute
where owner =
wner
and name = :name
and type = :type
order by line
:OWNER = EPMV3PRO
:NAME = BILLINGPKG
Duration = 0.203
Duration = 0.109
Duration = 0.109
Duration = 0.109
Duration = 0.109
10/5/2012 8:45:18 AM TOracleQuery $05D4BDC0 End (100 records processed)
Duration = 0.094
10/5/2012 8:45:18 AM TOracleQuery $05D4BDC0 Start Query.Next for up to 100 records
Duration = 0.094
Duration = 0.094
Duration = 0.109
Duration = 0.109
Duration = 0.109
Duration = 0.093
Duration = 0.094
Duration = 0.109
10/5/2012 8:45:19 AM TOracleQuery $05D4BDC0 End (100 records processed)
Duration = 0.11
10/5/2012 8:45:19 AM TOracleQuery $05D4BDC0 Start Query.Next for up to 100 records
Duration = 0.109
Duration = 0.109
Duration = 0.109
Duration = 0.109
Duration = 0.109
Duration = 0.093
Duration = 0.094
Duration = 0.093
10/5/2012 8:45:20 AM TOracleQuery $05D4BDC0 End (100 records processed)
Duration = 0.109
10/5/2012 8:45:20 AM TOracleQuery $05D4BDC0 Start Query.Next for up to 100 records
10/5/2012 8:45:20 AM TOracleQuery $05D4BDC0 End (43 records processed)
Duration = 0.109
10/5/2012 8:45:20 AM TOracleQuery $05D4BDC0 Start Query.Execute
SQL = select *
from sys.all_errors
wner
order by sequence
:NAME = BILLINGPKG
:OWNER = EPMV3PRO
10/5/2012 8:45:20 AM TOracleQuery $05D4BDC0 End (0 records processed)
Duration = 0.203
10/5/2012 8:45:20 AM ProcEditForm.GetTabNames
10/5/2012 8:45:20 AM + BILLINGPKG
10/5/2012 8:45:20 AM ProcEditForm.GetTabNames done
10/5/2012 8:45:20 AM TOracleQuery Query Start Query.Execute
:ID = Null
10/5/2012 8:45:20 AM TOracleQuery Query End
Duration = 0.094
10/5/2012 8:45:20 AM NavigationBookmarks.EnableButtons(Rebuild)
10/5/2012 8:45:20 AM NavigationBookmarks: Backward=0, Forward=0
10/5/2012 8:45:20 AM UpdateContents(Clear)
10/5/2012 8:45:20 AM Source = CREATE OR REPLACE PACKAGE BODY BILLINGPKG as
10/5/2012 8:45:20 AM UpdatingContents: Thread Started
10/5/2012 8:45:20 AM ContentsThread: Resume
10/5/2012 8:45:20 AM ContentsThread: Analyze
10/5/2012 8:45:20 AM ContentsThread: Valid
10/5/2012 8:45:20 AM ContentsThread: Suspend started
10/5/2012 8:45:20 AM LoadDesktop WindowName =
10/5/2012 8:45:20 AM SetSessionAction starts: Primary Session
10/5/2012 8:45:20 AM TOracleQuery $05D4BDC0 End (1 record processed)
Duration = 0.219
Duration = 0.109
10/5/2012 8:45:20 AM SetSessionAction ends
10/5/2012 8:45:20 AM LoadDesktop Window = 1
10/5/2012 8:45:20 AM WindowAllowed(1)
10/5/2012 8:45:20 AM WindowAllowed done
10/5/2012 8:45:20 AM Create TSQLForm Start
10/5/2012 8:45:20 AM Create TSQLForm Inherited
10/5/2012 8:45:21 AM TSQLForm.FormCreate Start
10/5/2012 8:45:21 AM Lock
10/5/2012 8:45:21 AM UnLock
10/5/2012 8:45:21 AM SQLForm
10/5/2012 8:45:21 AM TSQLForm.FormCreate Finished
10/5/2012 8:45:21 AM AddNavigationBookmark starts
10/5/2012 8:45:21 AM Create TSQLForm SetupMainFont
10/5/2012 8:45:21 AM Create TSQLForm Activate
10/5/2012 8:45:21 AM Create TSQLForm Activate done
10/5/2012 8:45:21 AM Create TSQLForm UpdateWindowList
10/5/2012 8:45:21 AM Create TSQLForm Positioning
10/5/2012 8:45:21 AM Create TSQLForm Finished
10/5/2012 8:45:21 AM LoadDesktop ChildListIndex = 1
10/5/2012 8:45:21 AM FileAge: C:\Users\csauer\Documents\epmdevWork\sql\copy_menu_to_production.sql = 5:53:44 AM
10/5/2012 8:45:21 AM LoadDesktop WindowName =
10/5/2012 8:45:21 AM SetSessionAction starts: Primary Session
10/5/2012 8:45:21 AM TOracleQuery $05D4B580 Start Query.Execute
10/5/2012 8:45:21 AM TOracleQuery $05D4B580 End (1 record processed)
Duration = 0.203
Duration = 0.109
10/5/2012 8:45:21 AM SetSessionAction ends
10/5/2012 8:45:21 AM LoadDesktop Window = -1
10/5/2012 8:45:21 AM NavigationBookmarks.EnableButtons(Rebuild)
10/5/2012 8:45:21 AM NavigationBookmarks: Backward=0, Forward=0
10/5/2012 8:45:21 AM DoUpdateChildList
10/5/2012 8:45:21 AM TOracleQuery Query Start Query.Execute
10/5/2012 8:45:21 AM TOracleQuery Query End (5 records processed)
Duration = 0.203
10/5/2012 8:45:21 AM SessionChanged SetDBAViews
10/5/2012 8:45:22 AM TOracleQuery $05D4B580 End (0 records processed)
Duration = 0.203
10/5/2012 8:45:22 AM TOracleQuery $05D4B580 Start Query.Execute
Duration = 0.203
10/5/2012 8:45:22 AM SessionChanged Authorizations.Load
10/5/2012 8:45:22 AM SessionChanged ApplyPreferences
10/5/2012 8:45:22 AM SortPreferenceSets
10/5/2012 8:45:22 AM - Default csauer
10/5/2012 8:45:22 AM - System Default
10/5/2012 8:45:22 AM SessionChanged EnableAuthorizedMenus
10/5/2012 8:45:22 AM WindowAllowed(1)
10/5/2012 8:45:22 AM WindowAllowed done
10/5/2012 8:45:22 AM ExecuteConnectScript starts
Duration = 0.109
Duration = 0.093
Duration = 0.109
10/5/2012 8:45:22 AM ExecuteConnectScript ends
10/5/2012 8:45:22 AM SetSessionAction starts: Primary Session
10/5/2012 8:45:23 AM TOracleQuery $05D4B580 End (1 record processed)
Duration = 0.203
10/5/2012 8:45:23 AM TOracleQuery $05D4B580 Start Query.Execute
Duration = 0.109
10/5/2012 8:45:23 AM SetSessionAction ends
10/5/2012 8:45:23 AM SessionChanged LoadRecentObjects
10/5/2012 8:45:23 AM SessionChanged Notify children
10/5/2012 8:45:23 AM Lock
10/5/2012 8:45:23 AM UnLock
10/5/2012 8:45:23 AM SessionChanged Logoff secondary sessions
10/5/2012 8:45:23 AM SessionChanged EnableChildFunctions
10/5/2012 8:45:23 AM NavigationBookmarks.EnableButtons(Rebuild)
10/5/2012 8:45:23 AM NavigationBookmarks: Backward=0, Forward=0
Found: oci.dll
10/5/2012 8:45:23 AM WindowAllowed(4)
10/5/2012 8:45:23 AM WindowAllowed done
10/5/2012 8:45:23 AM WindowAllowed(3)
10/5/2012 8:45:23 AM WindowAllowed(1)
10/5/2012 8:45:23 AM LoadDesktop ends
10/5/2012 8:45:23 AM FindPassword starts for epmv3@HPCRS
10/5/2012 8:45:23 AM Check current connections...
10/5/2012 8:45:23 AM Checking epmv3@ORACLE1...
10/5/2012 8:45:23 AM Checking epmv3pro@ORACLE1...
10/5/2012 8:45:23 AM Checking claims@oracle1...
10/5/2012 8:45:23 AM Checking x12@oracle1...
10/5/2012 8:45:23 AM Checking sys@HPCRS...
10/5/2012 8:45:23 AM Checking vim@oracle1...
10/5/2012 8:45:23 AM Checking citrus@ORACLE1...
10/5/2012 8:45:23 AM Checking plvision@ORACLE1...
10/5/2012 8:45:23 AM Checking sys@oracle1...
10/5/2012 8:45:23 AM Checking epmv3@HPCRS...
10/5/2012 8:45:23 AM Checking epmv2d@HPCRS...
10/5/2012 8:45:23 AM Checking citrus@apollo...
10/5/2012 8:45:23 AM Checking citrus@hpcrs...
10/5/2012 8:45:23 AM Checking claims@zeus...
10/5/2012 8:45:23 AM Checking x12@apollo...
10/5/2012 8:45:23 AM Checking sys@apollox...
10/5/2012 8:45:23 AM Checking citrus@apollox...
10/5/2012 8:45:23 AM Checking sys@ZEUS...
10/5/2012 8:45:23 AM Checking vim@apOLLO...
10/5/2012 8:45:23 AM Checking vim@ODEN...
10/5/2012 8:45:23 AM Checking vim@hPCRS...
10/5/2012 8:45:23 AM Checking vim@zEUS...
10/5/2012 8:45:23 AM Checking claims@APOLLOX...
10/5/2012 8:45:23 AM Checking epmv2d@apollox...
10/5/2012 8:45:23 AM Checking system@ORACLE1...
10/5/2012 8:45:23 AM Checking epmv2d@orACLE1...
10/5/2012 8:45:23 AM Check connection definitions...
10/5/2012 8:45:23 AM FindPassword ends for epmv3@HPCRS, no result
10/5/2012 8:45:23 AM FindPassword starts for epmv2d@HPCRS
10/5/2012 8:45:23 AM FindPassword ends for epmv2d@HPCRS, no result
10/5/2012 8:45:23 AM FindPassword starts for citrus@apollo
10/5/2012 8:45:23 AM FindPassword ends for citrus@apollo, no result
10/5/2012 8:45:23 AM FindPassword starts for citrus@hpcrs
