DOA not correct in D2009 IDE ?
Delphi IDE does not recognize DOA components.
In "Structure";
"Cannot resolve unit name 'Oracle ...'
In Sourcecode all properties to TOracleDataset etc are red the hint shows "TOracleDataset does not contain a member named 'open'"
(same for ALL DOA objects)
But I can compile!
I do have a path to DOA in the Library-list.
What is wrong ?
/uffe
There is only one way, but the error message is so strange that I wondered if there might be a version mix-up. Can you uninstall and reinstall?
Hello, we've got an other Problem with D2k9 IDE.
We're currently moving a large project from D7 to D2009.
After some modificactions it compiles fine and starts out of the IDE. During the login the call of "TOracleDataBase.Create" runs into an EAccessViolation and we didn't get any clue why. (However the database access itself works until this point without any problems with other DataSets...).
The other strange thing is that it will run without the IDE fine.
We're using Delphi 2009, Eurekalog 6.0.19, DOA 4.1.1 and Oracle 10gR2.
(Oracle 9i causes the same problem)
Any suggestions or help is appreciated.
Thanks in advance,
Peter
Sorry, my mistake,
I meant TOracleDataSet
The error occurs while creating a TCollection somewhere in TOracleDataSet.Create
From the disassembly I could trace down the occurence of the error somewhere during a TCollection.Create
Working function-calls before the error occurs are
TDataSet.Create
TOracleDataSet.GetMonID
TObject.Create
TSequenceField.Create
@UStrAsg
@UStrAsg
TOracleDictionary.Create
TQBEDefinition.Create
TObject.Create
TObject.Create
TObject.Create
TObject.Create
TCollection.Create (
I cannot imagine what could be wrong here. Can you create a little demo project that exhibits this behavior?
Ok,
thank you so far and sorry for the inconvenience.
The problem is a failing GetMem-Call during TObject.NewInstance, however I don't know why it didn't occure during the normal exececution - maybe I can set the reserved memory for debugging or somethink like that somewhere in the IDE.
I have to check that out...
