DOA is desconecting from Oracle
AlAtaKe
Hi
l'm having a serious problem with asta 2.6 in delphi 5 Enterprise and Oracle 8.1i running on UNIX.
My Asta Server is AstaDOAServer.
The problem is
I've 3 ASTA server aplications DOA running in W2K server in ports 9000, 9010
and 9020, with 20 clients each one
Sometimes one of this is disconnecting in Oracle obviusly the coneting clients on this, only recives the message "Not connected to oracle" or an exec error: "Not Logged On" if you take down the aplication in the task manager, when you start again the service, the aplication can't login to oracle but aplication is up and clients can connect, but don't have work without oracle conection.
Then I've reboot w2k.
What can I do for solved this bug?
The Astas's people see is a DOA problem
Luis Enrique Garcia A.
Hola,
Estoy teniendo un grave problema con los componentes asta 2.6 con delphi 5
Enterprise y Oracle 8.1i sobre UNIX
Mi Aplicacion servidora es AstaDOAServer
El problema es el siguiente
Tengo 3 aplicaciones servidoras DOA corriendo en un servidor windows 2000,
en los puertos 9000, 9010 y 9020, con aproximadamente 20 clientes cada una.
A veces una de las 3 se desconecta de oracle, obviamente, los clientes
conectados a esta solo reciben el mensaje "Not connected to oracle" si se da
de baja la aplicacion en el task manager y se levanta de nuevo el servicio,
no hace el login a oracle pero si levanta y se conectan los clientes y es
necesario reiniciar el server w2k
Como puedo corregir este bug?
Gracias
The "Not connected to oracle" message indicates that there was a problem on the server with this session. Can you verify if there is a user dump trace file on the database server that corresponds to this error, and if so, send it to me?
Similar threads
