DOA in OLE Automation Object under ASP/IIS
rkreykes
I am using DOA 3.3.3 in an OLE Automation Object object that is called from an Active Server Page under IIS 4.0. When a single client accesses the web page everything is fine, however, when 2 clients access the same page at the same time I get random abends. I am creating the TOracleSession dynamically and I am setting ThreadSafe to true.
I called Borland and they indicated that the cause was probably DOA.
Any help will be appreciated.
