Hello - I've used SQL Developer and SQL Plus intensively but have only just started with PL/SQL Developer (version 12.0.7.1837 (64 bit ) 01.120308 and Oracle database 12.2)
I have come across a couple of display inconsistencies with the three tools and I wanted to check that it was the tool and not me!
1. Dates - my database default is set to DD-MON-RR yet selecting a date column it gets displayed as 16-Jul-18 in PL/SQL Developer but the other two tools use 16-JUL-18. Is there a setting I can set to force it to use the default setting? I appreciate I can use TO_CHAR but I don't need to use that in either of the other tools and was wondering if there is a preference setting I'm missing.
2. SYSDATE also gets displayed differently ie PL/SQL Developer seems to display the time element by default where as the other two don't - is that expected behaviour? So 16-Jul-18 11:51:52 as opposed to 16-JUL-18
I've got my preferences set for dates to the Oracle format.
I appreciate these are quite small differences for most people but are quite important to my work.
Any help much appreciated
Regards
Helen
Regards
Helen
