Peter Zolja
Perhaps I don't understand correctly how dbms_output.disable works, but if I disable it (TOracleSession.DBMS_Output.Disable), it still works; meaning that I can access the output (DBMS_Output.Get_Lines).
If all I run is a PL/SQL block and I call "disable" from the same block it works, but subsequent blocks (where I don't call "disable") do get the output.
I guess my question is: How can disable the output at a session level? Some functions can use put_line and if the buffer is not big enough nothing is returned, so in some cases it would be useful to be able to completely disable the output.
Thank you.
Thank you.
