B bspierre Member Mar 21, 2002 #1 When I run the prepare method of the the DPL component I get the error: Access violation at address 606DA0A9 in module 'OraClient9.Dll'. Read of address 00000000 The same code works when using the 8.17 client. Is this is problem with the 9 client? Thanks
Marco Kalter Administrator Staff member Mar 25, 2002 #1 There does indeed seem to be a problem with the 9i client and direct path loading. We will look into this. ------------------ Marco Kalter Allround Automations
Roald Andresen Member² Apr 15, 2002 #1 This also seems to occur when using a class (generated by the package wizard) that has a procedure with a BLOB parameter. ------------------
Marco Kalter Administrator Staff member Apr 18, 2002 #1 BLOB parameters should work just fine. If you are experiencing a problem, perhaps you can send me a demo project to reproduce this. ------------------ Marco Kalter Allround Automations
B bspierre Member Apr 18, 2002 #1 Marco, What's the status of this issue? For the moment I'm using the oracle 8 client. Thanks
Marco Kalter Administrator Staff member Apr 19, 2002 #1 As far as we can see the Direct Path Loader API in the Oracle9i client appears to have a bug. That's all I know about it right now. ------------------ Marco Kalter Allround Automations
B bspierre Member May 19, 2003 #1 Has the bug been reported to Oracle? Could you give me the bug number? If it is their problem I would like to track it with them and ask them why it hasn't been fixed after a year. Thanks
