Direct Connection through Pl-SQL developer
prasath n
1) Is there option in PL-SQL developer to connect to db without having TNS entry, like the one we have in TOAD.
2) Can we connect to Oracle XE through PL-SQL developer?
Thanks for your time.
You can definitely connect to XE - I'm connected now.
As to how exactly, I'm not certain!
I just type a username and password and leave the 'Database' field blank. My Oracle Home is autodetected (as I have a few Oracle homes on this PC) but the dropdown list of databases suggests it's not using the XE home.
You can use the EZCONNECT naming method (host[:port][/service_name]) if Oracle Net is configured as such, or you can enter an entire connect descriptor (just like in a tnsnames.ora file) in the Database field.
Yes, no problem.
