Robert Mackovik
There is a difference between DDL I wrote on one DB, and difference script PL/SQL Developer generated using Compare User Objects.
Real command:
create unique index PK_POD_IDX on POD_POD (CISLO);
alter table POD_POD add constraint PK_POD primary key (CISLO) using index PK_POD_IDX;
PL/SQL Developer (compare user objects):
alter table POD_POD add constraint PK_POD primary key (CISLO);
The problem is, that executing such command can result into different state of target DB.
Is there a way how to fix the generation of diff script?
PL/SQL Developer version 15.0.4.2064, DB Oracle 19c.
Thank you.
Real command:
Thank you.
