PL/SQL Developer
Version 9.0.2.1621
Windows XP Professional 5.1 Build 2600 (Service Pack 3)
Physical memory : 2,097,152 kB (2,097,152 available)
Virtual memory : 2,097,024 kB (2,032,880 available)
Parameters
DebugSQL
Preferences
Session mode: Multi
OCI Library:
Use OCI7: False
Preference Files
Plug-Ins
3/21/2012 9:00:52 AM Application started
3/21/2012 9:00:52 AM InitPreferences
3/21/2012 9:00:52 AM Load C:\Program Files\PLSQL Developer\Preferences\Default = 0
3/21/2012 9:00:52 AM PreferenceSet.Load C:\Program Files\PLSQL Developer\Preferences\Default\Default.ini
3/21/2012 9:00:52 AM PreferenceSet.Load OK
3/21/2012 9:00:52 AM Determine LocalPrefPath
3/21/2012 9:00:52 AM [1]: C:\Program Files\PLSQL Developer\Preferences
3/21/2012 9:00:52 AM LocalPrefPath: C:\Program Files\PLSQL Developer\Preferences\ADB4312
3/21/2012 9:00:52 AM Load C:\Program Files\PLSQL Developer\Preferences\ADB4312 = 0
3/21/2012 9:00:52 AM PreferenceSet.Load C:\Program Files\PLSQL Developer\Preferences\ADB4312\default.ini
3/21/2012 9:00:52 AM PreferenceSet.Load C:\Program Files\PLSQL Developer\Preferences\ADB4312\user.prefs
3/21/2012 9:00:52 AM InitPreferences end
3/21/2012 9:00:52 AM SortPreferenceSets
3/21/2012 9:00:52 AM - Default ADB4312
3/21/2012 9:00:52 AM - System Default
3/21/2012 9:00:52 AM DoUpdateChildList
3/21/2012 9:00:52 AM pfReadRegistry(PL/SQL Developer\Shell\Open\Command, )
3/21/2012 9:00:52 AM ReadString OK
3/21/2012 9:00:52 AM pfReadRegistry: "C:\Program Files\PLSQL Developer\PLSQLDev.exe" "%1"
3/21/2012 9:00:52 AM LoadPreferences
3/21/2012 9:00:52 AM LoadPreferences searching for default
3/21/2012 9:00:52 AM C:\Program Files\PLSQL Developer\Preferences\ADB4312\default.ini
3/21/2012 9:00:52 AM LoadPreferences NewPref := nil
3/21/2012 9:00:52 AM LoadPreferences Reading preferences
3/21/2012 9:00:52 AM LoadPreferences ReadPosition
3/21/2012 9:00:52 AM LoadPreferences ToolsBrowserItemClick(nil)
3/21/2012 9:00:52 AM LoadPreferences CreateBrowserFilters...
3/21/2012 9:00:52 AM LoadPreferences Files
3/21/2012 9:00:52 AM LoadPreferences Buttons
3/21/2012 9:00:52 AM LoadPreferences Printer
3/21/2012 9:00:52 AM LoadPreferences FileBrowserFolders
3/21/2012 9:00:52 AM LoadPreferences Connections
3/21/2012 9:00:52 AM LoadPreferences BrowserFolders
3/21/2012 9:00:52 AM LoadPreferences end
3/21/2012 9:00:52 AM MacroLibFilename: C:\Program Files\PLSQL Developer\Macro\ADB4312.lib
3/21/2012 9:00:52 AM Adding new connection
3/21/2012 9:00:52 AM Username = adb4312
3/21/2012 9:00:52 AM Database = EDWPRO
3/21/2012 9:00:52 AM Username = cr_sandbox
3/21/2012 9:01:02 AM TOracleSession $02EFE930 Start Session.LogOn as adb4312@EDWPRO
3/21/2012 9:01:02 AM TOracleQuery Query Start Query.Execute
3/21/2012 9:01:02 AM TOracleQuery Query End (1 record processed)
Duration = 0
3/21/2012 9:01:02 AM TOracleSession $02EFE930 End
Duration = 0.141
3/21/2012 9:01:02 AM TOracleQuery $02EA60C0 Start Query.Execute
3/21/2012 9:01:02 AM TOracleQuery $02EA60C0 End (1 record processed)
Duration = 0
3/21/2012 9:01:02 AM TOracleSession $02EFEBD0 Start Session.LogOn as adb4312@EDWPRO
Duration = 0
3/21/2012 9:01:02 AM TOracleSession $02EFEBD0 End
Duration = 0.094
SQL = select * from v$version
3/21/2012 9:01:02 AM TOracleQuery BytesPerCharacterQuery Start Query.Execute
3/21/2012 9:01:02 AM TOracleQuery Query End (5 records processed)
Duration = 0.015
3/21/2012 9:01:02 AM TOracleQuery $02EA5E00 Start Query.Execute
sys.plsqldev_authorization
3/21/2012 9:01:02 AM TOracleQuery BytesPerCharacterQuery End (1 record processed)
Duration = 0.015
Duration = 0
3/21/2012 9:01:02 AM TOracleQuery $02EA6220 Start Query.Execute
SQL = /*
The name + type results of these queries will be used by the Code Assistant
if the "Describe Context" option is enabled. After typing 3 or more characters
the Code Assistant will show a list of matching names.
Separate multiple queries with semi-colons and use the :schema bind variable
to restrict names to the currently connected user.
In case of an error the query results will be omitted. No error message will
be displayed.
Place this file in the PL/SQL Developer installation directory for all users,
or in the "%APPDATA%\PLSQL Developer" directory for a specific user.
select object_name, object_type
from sys.all_objects o
where o.owner = :schema
:SCHEMA = ADB4312
3/21/2012 9:01:02 AM TOracleQuery $02EA6220 End (0 records processed)
Duration = 0
SQL =
select s.synonym_name as object_name, o.object_type
from sys.all_synonyms s, sys.all_objects o
where s.owner in ('PUBLIC', :schema)
and o.owner = s.table_owner
:SCHEMA = ADB4312
3/21/2012 9:01:02 AM TOracleQuery $02EA5E00 End
Duration = 0
3/21/2012 9:01:02 AM LogonHistorySave start
3/21/2012 9:01:02 AM ChangeUserPref LogonHistory,
3/21/2012 9:01:02 AM ChangeUserPref DSA,
3/21/2012 9:01:02 AM ChangeUserPref end
3/21/2012 9:01:02 AM ChangeUserPref ColumnAssociations,
3/21/2012 9:01:02 AM ChangeUserPref ImportAssociations,
3/21/2012 9:01:02 AM ChangeUserPref BrowserFilters,
3/21/2012 9:01:02 AM ChangeUserPref FileBrowserFolders,
3/21/2012 9:01:02 AM ChangeUserPref Connections,
3/21/2012 9:01:02 AM ChangeUserPref BrowserFolders,
3/21/2012 9:01:02 AM ChangeUserPref SessionQueries,
3/21/2012 9:01:02 AM ChangeUserPref ExternalTools,
3/21/2012 9:01:02 AM ChangeUserPref Documents,
3/21/2012 9:01:02 AM ChangeUserPref Reports,
3/21/2012 9:01:02 AM ChangeUserPref CurrentConnections,
3/21/2012 9:01:02 AM PreferenceSet.Save
3/21/2012 9:01:02 AM PreferenceSet Filename = C:\Program Files\PLSQL Developer\Preferences\ADB4312\user.prefs
3/21/2012 9:01:02 AM PreferenceSet AltFile = user.prefs
3/21/2012 9:01:02 AM PreferenceSet.Save end
3/21/2012 9:01:02 AM LogonHistorySave end
3/21/2012 9:01:02 AM FormCreate Logon.Executed -1
3/21/2012 9:01:02 AM FormCreate SessionChanged
Duration = 0.015
3/21/2012 9:01:02 AM TOracleQuery $02EA5E00 End (1 record processed)
Duration = 0
3/21/2012 9:01:02 AM SessionChanged SetDBAViews
3/21/2012 9:01:02 AM TOracleQuery $02EA5E00 End (0 records processed)
Duration = 0.016
Duration = 0.016
Duration = 0
Duration = 0
SQL = select object_name from sys.dba_objects where owner = 'SYS' and object_type = 'VIEW' and object_name like 'DBA%'
Duration = 0.015
SQL = select object_name from sys.all_objects where owner = 'SYS' and object_type = 'VIEW' and object_name like 'DBA%'
3/21/2012 9:01:03 AM TOracleQuery $02EA5E00 End (5 records processed)
Duration = 0.282
3/21/2012 9:01:03 AM SessionChanged Authorizations.Load
3/21/2012 9:01:03 AM SessionChanged EnableAuthorizedMenus
3/21/2012 9:01:03 AM WindowAllowed(1)
3/21/2012 9:01:03 AM WindowAllowed done
3/21/2012 9:01:03 AM ExecuteConnectScript starts
3/21/2012 9:01:03 AM TOracleQuery $02EA5E00 Start Query.Execute
SQL = alter session set plsql_optimize_level = 2
Duration = 0
SQL = alter session set plsql_code_type = interpreted
Duration = 0
3/21/2012 9:01:03 AM ExecuteConnectScript ends
3/21/2012 9:01:03 AM SetSessionAction starts: Primary Session
SQL = select null from dual
3/21/2012 9:01:03 AM TOracleQuery $02EA5E00 End (1 record processed)
Duration = 0
:ACTION = Primary Session
Duration = 0
3/21/2012 9:01:03 AM SetSessionAction ends
3/21/2012 9:01:03 AM SessionChanged LoadRecentObjects
3/21/2012 9:01:03 AM SessionChanged Notify children
3/21/2012 9:01:03 AM SessionChanged Logoff secondary sessions
3/21/2012 9:01:03 AM SessionChanged EnableChildFunctions
OCIDLL forced to C:\oracle\ora102\bin\oci.dll
3/21/2012 9:01:03 AM Lock
3/21/2012 9:01:03 AM UnLock
3/21/2012 9:01:03 AM TOracleQuery $02EA6220 End (100 records processed)
Duration = 0.766
3/21/2012 9:01:03 AM TOracleQuery $02EA6220 Start Query.Next for up to 100 records
Duration = 0
Duration = 0.015
3/21/2012 9:01:03 AM SortPreferenceSets
3/21/2012 9:01:03 AM - Default ADB4312
3/21/2012 9:01:03 AM - System Default
3/21/2012 9:01:03 AM TOracleQuery $02EA5E00 End (0 records processed)
Duration = 0.015
Duration = 0
3/21/2012 9:01:03 AM DoUpdateChildList
3/21/2012 9:01:03 AM FormActivate start
3/21/2012 9:01:04 AM FormActivate end
3/21/2012 9:01:04 AM WMUpdatePopups starts
3/21/2012 9:01:04 AM Adding new connection
3/21/2012 9:01:04 AM Username = adb4312
3/21/2012 9:01:04 AM Database = EDWPRO
3/21/2012 9:01:04 AM Username = cr_sandbox
3/21/2012 9:01:04 AM LoadDesktop starts
3/21/2012 9:01:04 AM DoUpdateChildList
3/21/2012 9:01:04 AM Lock
3/21/2012 9:01:04 AM UnLock
3/21/2012 9:01:04 AM TOracleQuery Query Start Query.Execute
3/21/2012 9:01:04 AM TOracleQuery Query End (5 records processed)
Duration = 0
3/21/2012 9:01:04 AM SessionChanged SetDBAViews
3/21/2012 9:01:04 AM TOracleQuery $02EA5E00 Start Query.Execute
3/21/2012 9:01:04 AM TOracleQuery $02EA5E00 End (0 records processed)
Duration = 0
Duration = 0.015
3/21/2012 9:01:04 AM SessionChanged Authorizations.Load
3/21/2012 9:01:04 AM SessionChanged ApplyPreferences
3/21/2012 9:01:04 AM SortPreferenceSets
3/21/2012 9:01:04 AM - Default ADB4312
3/21/2012 9:01:04 AM - System Default
3/21/2012 9:01:04 AM SessionChanged EnableAuthorizedMenus
3/21/2012 9:01:04 AM WindowAllowed(1)
3/21/2012 9:01:04 AM WindowAllowed done
3/21/2012 9:01:04 AM ExecuteConnectScript starts
Duration = 0
Duration = 0
3/21/2012 9:01:04 AM ExecuteConnectScript ends
3/21/2012 9:01:04 AM SetSessionAction starts: Primary Session
3/21/2012 9:01:04 AM TOracleQuery $02EA5E00 End (1 record processed)
Duration = 0
Duration = 0
3/21/2012 9:01:04 AM SetSessionAction ends
3/21/2012 9:01:04 AM SessionChanged LoadRecentObjects
3/21/2012 9:01:04 AM SessionChanged Notify children
3/21/2012 9:01:04 AM SessionChanged Logoff secondary sessions
3/21/2012 9:01:04 AM SessionChanged EnableChildFunctions
3/21/2012 9:01:04 AM LoadDesktop ends
3/21/2012 9:01:04 AM WMUpdatePopups ends
3/21/2012 9:01:06 AM TOracleQuery $02EA6220 End (100 records processed)
Duration = 2.36
3/21/2012 9:01:06 AM TOracleQuery $02EA6220 Start Query.Next for up to 100 records
Duration = 0.64
Duration = 0.079
Duration = 0.171
3/21/2012 9:01:09 AM TOracleQuery $02EA6220 End (100 records processed)
Duration = 2.094
3/21/2012 9:01:09 AM TOracleQuery $02EA6220 Start Query.Next for up to 100 records
Duration = 0.547
3/21/2012 9:01:10 AM TOracleQuery $02EA6220 End (100 records processed)
Duration = 1.188
3/21/2012 9:01:10 AM TOracleQuery $02EA6220 Start Query.Next for up to 100 records
Duration = 0.078
Duration = 0.015
Duration = 0
Duration = 0.016
3/21/2012 9:01:11 AM TOracleQuery $02EA6220 End (89 records processed)
Duration = 0.516
3/21/2012 9:01:11 AM TOracleQuery $02EA6220 Start Query.Execute
SQL =
select db_link as object_name, 'DATABASE LINK' as object_type
from sys.all_db_links o
or o.owner = 'PUBLIC'
:SCHEMA = ADB4312
3/21/2012 9:01:11 AM TOracleQuery $02EA6220 End (13 records processed)
Duration = 0.015
3/21/2012 9:01:11 AM TOracleSession $02EFEBD0 Start Session.LogOff
3/21/2012 9:01:11 AM TOracleSession $02EFEBD0 End
Duration = 0
3/21/2012 9:01:12 AM Create TSQLForm Start
3/21/2012 9:01:12 AM Create TSQLForm Inherited
3/21/2012 9:01:12 AM TSQLForm.FormCreate Start
3/21/2012 9:01:12 AM Lock
3/21/2012 9:01:12 AM UnLock
3/21/2012 9:01:12 AM SQLForm
3/21/2012 9:01:12 AM TSQLForm.FormCreate Finished
3/21/2012 9:01:12 AM Create TSQLForm SetupMainFont
3/21/2012 9:01:12 AM Create TSQLForm Activate
3/21/2012 9:01:12 AM UpdateChildList [timer]
3/21/2012 9:01:12 AM Create TSQLForm Activate done
3/21/2012 9:01:12 AM Create TSQLForm UpdateWindowList
3/21/2012 9:01:12 AM Create TSQLForm Positioning
3/21/2012 9:01:12 AM Create TSQLForm Finished
3/21/2012 9:01:13 AM Lock
3/21/2012 9:01:13 AM UnLock
3/21/2012 9:01:13 AM FileAge: Q:\D943\F11701\SECURED\PHI\Analytic Team Folder\Automated Reports\PlanCompass Commercial\Step 1 code.sql = 8:59:44 PM
3/21/2012 9:01:13 AM SQLForm
3/21/2012 9:01:13 AM NavigationBookmarks.EnableButtons(Rebuild)
3/21/2012 9:01:13 AM NavigationBookmarks: Backward=0, Forward=0
3/21/2012 9:01:13 AM CheckFileDate WindowFileDate = 8:59:44 PM
3/21/2012 9:01:13 AM DoUpdateChildList
3/21/2012 9:01:17 AM SQLForm Initializing...
3/21/2012 9:01:17 AM SetConnected starts
3/21/2012 9:01:17 AM SetConnected: Connect starts
3/21/2012 9:01:17 AM TOracleSession $02F01870 Start Session.LogOn as adb4312@EDWPRO
3/21/2012 9:01:17 AM TOracleQuery Query Start Query.Execute
3/21/2012 9:01:17 AM TOracleQuery Query End (1 record processed)
Duration = 0
3/21/2012 9:01:17 AM TOracleSession $02F01870 End
Duration = 0.094
3/21/2012 9:01:17 AM SetConnected: (Dis)connect ends
3/21/2012 9:01:17 AM SetSessionAction starts: SQL Window - Step 1 code.sql
3/21/2012 9:01:17 AM TOracleQuery $02E68970 Start Query.Execute
3/21/2012 9:01:17 AM TOracleQuery $02E68970 End (1 record processed)
Duration = 0
3/21/2012 9:01:17 AM TOracleQuery BytesPerCharacterQuery Start Query.Execute
3/21/2012 9:01:17 AM TOracleQuery BytesPerCharacterQuery End (1 record processed)
Duration = 0
Duration = 0.015
:ACTION = SQL Window - Step 1 code.sql
Duration = 0
3/21/2012 9:01:17 AM SetSessionAction ends
3/21/2012 9:01:17 AM ExecuteConnectScript starts
Duration = 0
Duration = 0
3/21/2012 9:01:17 AM ExecuteConnectScript ends
Duration = 0.016
3/21/2012 9:01:17 AM EnableOutput starts
3/21/2012 9:01:17 AM TOracleQuery PLSQLDevForm.EnableOutputQuery Start Query.Execute
SQL = begin
if :enable = 0 then
sys.dbms_output.disable;
else
sys.dbms_output.enable
size);
end if;
:ENABLE = 1
:SIZE = 10000
3/21/2012 9:01:17 AM TOracleQuery PLSQLDevForm.EnableOutputQuery End
Duration = 0
3/21/2012 9:01:17 AM EnableOutput done
3/21/2012 9:01:17 AM InitStatistics starts
3/21/2012 9:01:17 AM TStatistics.Init starts
3/21/2012 9:01:17 AM InitStatNames starts
3/21/2012 9:01:17 AM select name from v$statname order by statistic#
3/21/2012 9:01:17 AM TOracleQuery $02EA59E0 Start Query.Execute
SQL = select name from v$statname order by statistic#
3/21/2012 9:01:17 AM TOracleQuery $02EA59E0 End (371 records processed)
Duration = 0
3/21/2012 9:01:17 AM 371 statistics found
3/21/2012 9:01:17 AM StatQuery.ReadBuffer = 372
3/21/2012 9:01:17 AM InitStatNames ends
3/21/2012 9:01:17 AM StatQuery.Describe starts
3/21/2012 9:01:17 AM TOracleQuery $02E68970 Start Query.Describe
SQL = select value from v$sesstat where sid = :sid order by statistic#
:SID = Null
Duration = 0.016
3/21/2012 9:01:17 AM StatQuery.Describe ends
3/21/2012 9:01:17 AM TStatistics.Init ends
3/21/2012 9:01:17 AM InitStatistics ends
3/21/2012 9:01:17 AM CreateQueryTabs starts
3/21/2012 9:01:20 AM GotoQueryTab 0
3/21/2012 9:01:20 AM GotoQueryTab: QueryTabControlChanging
3/21/2012 9:01:20 AM GotoQueryTab: QueryTabControlChange
3/21/2012 9:01:20 AM GotoQueryTab done
3/21/2012 9:01:20 AM CreateQueryTabs ends
3/21/2012 9:01:20 AM SQLForm
3/21/2012 9:01:20 AM TOracleQuery Query Start Query.Execute
:ID = Null
3/21/2012 9:01:20 AM TOracleQuery Query End
Duration = 0
3/21/2012 9:01:23 AM CheckFileDate WindowFileDate = 8:59:44 PM
3/21/2012 9:01:23 AM FileAge: Q:\D943\F11701\SECURED\PHI\Analytic Team Folder\Automated Reports\PlanCompass Commercial\Step 1 code.sql = 8:59:44 PM
3/21/2012 9:01:23 AM NavigationBookmarks.EnableButtons(Rebuild)
3/21/2012 9:01:23 AM NavigationBookmarks: Backward=0, Forward=0
3/21/2012 9:04:37 AM CheckFileDate WindowFileDate = 8:59:44 PM
3/21/2012 9:04:37 AM FileAge: Q:\D943\F11701\SECURED\PHI\Analytic Team Folder\Automated Reports\PlanCompass Commercial\Step 1 code.sql = 8:59:44 PM
3/21/2012 9:04:37 AM NavigationBookmarks.EnableButtons(Rebuild)
3/21/2012 9:04:37 AM NavigationBookmarks: Backward=0, Forward=0
