Delete All prompt when deleting from SQL window
damion
I was wondering if there is a way to disable the prompt to acknowledge a Delete of all records from a table when in a SQL window. I'm in a SQL window and just type in "Delete from table_name" and execute that and the first thing that happens is a popup that asked "Are you sure you want to delete all records?". I don't want that prompt and was wondering if I could turn it off.
In the upcoming 5.1.3 patch release you will only get this message once (if you confirm it) for the duration of the PL/SQL Developer session.
If requiring an exclusive lock on the table is not a problem, which I assume it isn't, as we are deleting every single row, why not use:
TRUNCATE TABLE table_name REUSE STORAGE;
instead of
DELETE FROM table_name;
- Much faster on large tables
- No questions later, about validity of "missing" WHERE in delete code.
- Oh, and no pop-up
Just a thought.
Hakuna Matata,
Arnoud.
[This message has been edited by aotte (edited 09 July 2003).]
