I had a connection drop while debugging, and now I can't close the window.
If I try and close the window, I get "Test window cannot be closed, Script is still executing". When I click 'Terminate', I get "Error during debug step: ORA-03114 - not connected to ORACLE/Debugging session terminated", but the debug session is not terminated (the red 'Break' lightning bolt is still visible, and the green 'Go' arrow is still visible).
If I click on the Break or Go buttons, I get "Error during debug step: ORA-03114 - not connected to ORACLE/Debugging session terminated".
If I try and log back in, I get "You cannot log on as another user while one or more windows are still executing".
My only choice is to terminate the PL/SQL Developer process.
I have had a similar problem occur once before with a long query that died (and I wasn't able to close the window or terminate the query). Can something be done to handle what happens after being disconnected from Oracle?
Juan
Juan
