debug mode quits responding when hovering field.
pl/sql developer quits responding when debugger is turned on and I hover a field to display the contents. Also happens when I add field to display list during debug mode.
I then have to cancel the task via task manager and start pl/sql setup all over again. This happens continuously until I cannot hover or debug and only step thru the code without the benefit of displaying field contents. This is getting very wasteful and time consuming. I need to resolve this asap for the tool to be used to it's best potential.
Your help is desperately needed....thanks.
Current version installed is '5.1.6.747 02.10133 - unlimited user license'
To obtain some more diagnostic information, can you modify the shortcut and add the debug parameter? For example:
"C:\Program Files\PLSQL Developer\plsqldev.exe" debug
