Debug issues
Dave876
TT.PROC1 makes a call to XX.PROC2.
XX.PROC2 is owned by another schema and executes :
select count(1) from tablea where col1 = parsed_val;
tablea is owned by the same schema as XX.PROC2.
The record definately exists in tablea - running the query manually returns the correct result.
If I execute the full procedure without trying to debug it (I am using PL/SQL Developer 7.1) it will run fine. When I try to step through the count does not find any matches - and screws everything up.
Is this a permissions thing? Or is the 'focus' changed somehow when debugging?
Any help would be great!!
Cheers,
David.
Do you mean that the results are different when you run the program in debug mode (F9) compared to normal mode (F8)?
