DEBUG Issue
cct
Using version 13.0.4.1906 32 bit on Win server 2008 R2
I am trying to runb teh PL/SQL debugger on a package that is not behaving.
I create test script and run. Then step through till I get the package module call, but step into just moves to the next step in the test script. It does execute the module. I have tried setting a breakpoint in the module and recompiling, but no joy.
I have also tried with the same ersion on my Win 10 laptop - same issue.
In both cases I have checked that Add debug Information is ticked for the spec and the body.
Any ideas?
This is rather urgent as I am being pressed to prove or fix this code.
Chris
Perhaps you are connected to the database as a different user than the package owner? If so, can you obtain the DEBUG ANY PROCEDURE system privilege and try again?
