now I shall explain the subject:
If you create a job with a case sensitive name, for ex. HR."RegularTask"
DBMS_Scheduler will show it's name corecly, but when you try to change something, for ex Disable the Job, the UI will generate the following SQL:
sys.dbms_scheduler.disable(name => 'HR."REGULAR_TASK"');
This sql will obviously fail.
It seems to me that UI uppercase every object name when generating SQL, wich is not correct.
Could you please fix this.
