I did find other info in the forums on this, but nothing on how to do specifically what I need. I want to right-click the package in the objects explorer and extract the metadata (spec and body) into a single file.
Using v11.0.6.1176
UPDATE:
Scratch that request - just figured it out.
1. Edit or view spec&body (from the right-click menu)
2. Right-click in the editor window, choose 'Copy Window to...SQL Window'
Would be nice if I could do that in a single right-click step, though.
Using v11.0.6.1176
UPDATE:
