Dates range with QBE
mclot
Is there a way to manage dates range using QBE on OracleDataset?
I display my data using an InfoPower grid; when I activate the QBE, the date fields display the calendar combo and so you can select only 1 date, thus no range is permitted.
Thanks.
Massimo
I'm sorry. I just tried to disable the calendar combo on the InfoPower grid and now I can use operators on date fields too. And QBE works fine! The only disadvantage is that users must know how to format the date in the grid cell (i.e. "dd/mm/yyyy").
Massimo
