Date problem in the SQL Window
DLab
When using an SQL Window to query data, I am getting the following error when I click on the small arrow beside a date column :
Overflow while converting variant of type (Date) into type (Date).
Is there a way to fix this?
That sounds like an old bug. What is your PL/SQL Developer version (Help > About screen)?
Our version is 5.0.2.499
01.9265
Where can I get an upgrade? Only the trial version is available on the website.
I will send you all necessary upgrade information by e-mail. After the upgrade, the problem should be fixed.
Thanks for the great support!
PL/Sql Developer is an excellent product that I would not work without.
