Database connections drop down not fully populated.
Willow
Using V9 of PL/SQL Developer, when I first start it up and get the list of database connections, not all entries are shown in the drop down list.
If I look at the TNS Names tab in support info, I can see that the correct TNS Names is being shown.
If I manually type in an entry that is in the TNSNames but not in the drop down list, I can successfully connect.
Am I missing something?
Never mind, found the problem.
There was a bracket missing in the TNSnames file, one of the entries was not correctly terminated. After adding the bracket, the drop down list is populated correctly.
