Data Generator: How to generate random dates between min and max?
ifernan
Hi.
I have been reading User's Guide and I have discover this for Random function of Data Generator:
"Random([Min], Max) Returns random numbers between Min and Max. If only Max is specified, Min is set to 0. For date fields you can enter dates for Min and Max."
But I am missing something because I have tried several ways for setting min and max value of the date and nothing works for me.
I have tried:
- Random('01/01/2016','01/05/2016')
- Random(date '2016-01-01', date '2016-05-01')
- Random((to_date('01/01/2016','DD/MM/YYYY'),to_date('01/05/2016','DD/MM/YYYY'))
- Random(SQL(to_date('01/01/2016','DD/MM/YYYY')),SQL(to_date('01/05/2016','DD/MM/YYYY')))
Can anyone help me? How can I set min and max value for a date in Random function?
Regards.
You can use the following syntax:
random(01/01/2016, 01/05/2016)
It's a bit odd that the quotes are not allowed.
Also note that the date format must match your client settings (windows format or as overruled in the NLS preferences).
An alternative:
SQL(trunc(sysdate + dbms_random.value * 364))
This will generate random dates between the current date and 364 days later.
Thanks for your answer!
Now it's working fine. It's really a bit odd not to use quotes. :crazy:
I think Data Generator is a good tool but it's missing a big set of examples of any of the functions available. At least in my case, I am discovering how things works by try and error.
