TenGor
Hy,
i like the Data Generator very much, but i had a little suggestion:
i know that i can use the fuction Sequence.
But there is no possibility to use a DB-Sequence.
So if i use the "Data Generator Sequence" my sequence for the table is on the false id.
When i insert some test data by hand i get an error because the PK is already in there...
Ok, i can update the DB-Sequece by hand too, but it would by very nice just using it within Data Generator.
