With Delphi5 with DOA 3.45 compos (for D5), I'm able to execute the next code:
procedure TForm1.Button1Click(Sender: TObject);
if pkgTest.CallBooleanFunction
('TEST_DOA_INT_RET_BOOL', ['p_int', 0])
then
Edit1.Text := 'True'
else
Edit1.Text := 'False';
But with Delphi6 with DOA 3.45 compos (for D6), I have the message:
Project Project1.exe raised exception class Exception with message
'Byte parameters can only be used for output parameter types'.
Process stopped. Use Step or Run to continue.
If I use the next code, it works:
var
wkInt : Integer;
wkInt := 0;
wkInt])
then
else
Why???
Here it's the code of my package:
CREATE OR REPLACE PACKAGE TEST IS
FUNCTION TEST_DOA_INT_RET_BOOL(p_Int IN PLS_INTEGER) RETURN BOOLEAN;
END TEST;
CREATE OR REPLACE PACKAGE BODY TEST AS
FUNCTION TEST_DOA_INT_RET_BOOL(p_Int IN PLS_INTEGER) RETURN BOOLEAN IS
IF p_Int = 0 THEN
RETURN False;
ELSE
RETURN True;
END IF;
END TEST_DOA_INT_RET_BOOL;
END TEST;
then
else
var
wkInt : Integer;
wkInt := 0;
wkInt])
then
else
Why???
END TEST;
IF p_Int = 0 THEN
RETURN False;
ELSE
RETURN True;
END IF;
END TEST;
