Customize SQL> prompt
RobertK
My point in my last post "Login Script"
is really about customizing the SQL> Prompt in the command window....
Is this doable in 5.1.3 ?
No, the set prompt command is not supported.
Through Tools > Preferences > Appearance you can set connection indicators though. You could for example define a red background color when connected to a production database, a yellow background when connected through a DBA account, and so on.
