Customize Quick Access Toolbar Problem
Oguz
I am using v15 pl/sql developer. So i customized some options for me, but i want to change to large to this icons at the red area, its belong at the picture. I find a option in more commands / option tab but its not work for me.
And i want to move this icons location, is there any way for that?
Thank you.
You cannot use large icons for the toolbars. They will always show small icons.
If you select "More commands" from the menu, you can rearrange the icons through drag & drop directly in the toolbar.
The Quick Access Toolbar cannot really be moved. It can only be located above or below the Ribbon. You would need to create a new toolbar from the "More commands" option, add commands to it, and place the toolbar at the desired location through drag & drop.
