D David Best Member Mar 9, 2004 #1 We have DOA 4.0.3 Is there a way to return a cursor from an external stored procedure? TIA
Marco Kalter Administrator Staff member Mar 10, 2004 #1 Are you writing the external stored procedure using DOA, or do you want to call the external stored procedure from DOA?
K koadam Member² Mar 10, 2004 #1 Hi, A'm also interested in the above question. I want to write the external function/procedure with doa, returning a cursor. The client-side will be delphi applications using DOA and ODAC components. B.
D David Best Member Mar 10, 2004 #1 The external stored procedure is written in Delphi using DOA and is called from pl/sql.
Marco Kalter Administrator Staff member Mar 11, 2004 #1 Unfortunately this is currently not supported. You can only pass scalar data types such as strings, numbers, and dates.
