current functionality to rename constraints and indexes not used
Bernhard S
When you rename a constraint or an index in the "Edit table" window and you check out the resulting sql, you can see that PSD does the change via drop/recreate of the constraint/index.
However since Oracle 9i PSD should better use the following renaming sql syntax:
ALTER TABLE test RENAME CONSTRAINT test1_pk TO test_pk;
ALTER INDEX test1_pk RENAME TO test_pk;
This also avoids problems with depending objects like FKs on these PKs.
The same applies to the resulting SQL from "Compare User Objects".
