Cross-reference with plsqldoc plug-in
This works okay for me. Please make sure that you are using the latest 1.1 release of the plsqldoc Plug-In.
Thank you for your support.
We are using Plsqldoc 1.1.0 with PL/SQL Developer 5.1.3.704
Apart "Search cross-references", is there any options or conditions that may influence the cross-reference behavior?
Currently, the only situation for which it works it's for some tables. The column types for a table appear as hyperlinks for my user types.
For my types and my packages, the variable types never appear as hyperlinks. I would like to know for what reason.
Thanks.
