Crazy clicks to test a function
TenGor
Hy,
found something crazy in Version 5.1.4.728
I'm in a Package and want to test a procedure/function.
When i right-click on the name a (new?) context-menu appears (HTML Manuals, Explain Plan, Query Builder..)
When i click now somewhere else on the screen (no difference between left or rigth) the normal context-menu appears (Go to, Describe, Test..)
Is this a bug or feature? :confused:
Hy,
i have sent 2 pics to you.
I recognized that this problem take only effect with a File (Package in Program Window) which is write-protected.
Hy,
i think the source file is ok...
Perhaps the problem comes up because i use the VCS-Plugin with Microsoft VSS.
When i try it to a package, which is not in VSS then the normal context-menu appears (Go to, Describe, Test..)
If the packages in in VSS then the described effect comes up. (wether the file is checked in or out)
