could not locate oci.dll
Andres
I'm using DOA 3.4.4 with Delphi 5.
When I try to connect to Oracle I have a error messagge:
Could not locate OCI.dll
OracleHomeKey: Software/Oracle/Home0
OracleHomeDir: c:\oracle\ora90
I have installed Oracle Client version 7 and 8 in my PC, and I have had installed Oracle Client version 9 but I have desinstalled it.
Regards
If you uninstalled the 9i client, you should use the Oracle Home Selector and select the appropriate Primary Oracle Home. As a result the PATH environment variable will be modified, and Direct Oracle Access will be able to find the OCI Library.
The solution that you have given me is OK.
Thank you very much.
