Here is a simple text, that I want to convert to comment:
-- begin
/*O*/ test -- ID's
/*N*/ test -- Syntax: 'test'
-- end
If the entire text is selected and then changed by using [Edit|Selection|Comment], you will get the following result:
-- begin
\*O*\ test -- ID's
-- end
It seems that the comments in the line are misinterpreted.
tested with v13.0.1 (32) w10
-- begin
/*O*/ test -- ID's
-- end
-- begin
\*O*\ test -- ID's
-- end
