Constraints starting with SYS are not visible.
jrow
When I display a table's constraints the constraints starting with SYS are not visible. Is this a feature that I can turn off?
Thanks - JR
SQL> select * from user_constraints where table_name = 'ADJUSTMENT_TYPE';
OWNER CONSTRAINT_NAME CONSTRAINT_TYPE TABLE_NAME SEARCH_CONDITION R_OWNER R_CONSTRAINT_NAME DELETE_RULE STATUS DEFERRABLE DEFERRED VALIDATED GENERATED BAD RELY LAST_CHANGE INDEX_OWNER INDEX_NAME INVALID VIEW_RELATED
NEXTFARE_MAIN SYS_C006913 C ADJUSTMENT_TYPE "ADJUSTMENT_TYPE_ID" IS NOT NULL ENABLED NOT DEFERRABLE IMMEDIATE NOT VALIDATED USER NAME 02/11/2009 10:31:35
NEXTFARE_MAIN SYS_C006914 C ADJUSTMENT_TYPE "SHORT_DESC" IS NOT NULL ENABLED NOT DEFERRABLE IMMEDIATE NOT VALIDATED USER NAME 02/11/2009 10:31:35
NEXTFARE_MAIN PK_ADJUSTMENT_TYPE P ADJUSTMENT_TYPE ENABLED NOT DEFERRABLE IMMEDIATE NOT VALIDATED USER NAME 02/11/2009 10:31:35 NEXTFARE_MAIN PK_ADJUSTMENT_TYPE
Executed in 0.156 seconds
