Laurent Boutet
Hi, (a long time since i havent been posting something here ;-))
Here is the following error message i get when i try to connect :
Initialization Error
SQL *Net not properly installed
OracleHomeKey: SOFTWARE\ORACLE
OracleHomeDir:
I must tell you my config :
I have an oracle server and a client computer without Oracle installed on it.
This error occurs on the client computer without oracle installed.
I just use environnment variables to use oracle set in a batch file. Here is the .bat :
set ORACLE_HOME=G:\
set ORACLE_SID=CAPTURE
set PATH=%ORACLE_HOME%\bin;C:\program;%SystemRoot%\system32;%SystemRoot%;d:\oracle\bin
set TNS_ADMIN=D:\oracle\network\admin
d:
cd "d:\ConnexionOracle\"
start ConnexionOracle.exe
ConnexionOracle.exe is a delphi application with DOA. I try to connect with it and get the error at the beginning of the post.
Can you help me ?
I must use oracle on computers without Oracle installed...is that possible with DOA ?
Last thing to say : the oracle environment variables setting seems to be allright : indeed, server manager works fine from my client computer after lanuching the .bat file(without oracle !!).
Thanks in advance,
Laurent.
OracleHomeDir:
set ORACLE_HOME=G:\
d:
Can you help me ?
Thanks in advance,
Laurent.
