Hi Marko. You said to me that in new version you will make some changes in Connections. So because now you have beta 13 I hope that at least some of them you will be able to give in that 13..
1 - Collapse all folders - its really hard to add new connection from recent to folder which is on upper, because allways when I open Define connections all folders are not collapsed and I must close them one by one, or scroll too much to get to the upper one. So please give option into connection to collapse or expand all folders.
2 - Recent - please do there option to clear recent connections. After day or two of running plsqldeveloper recent connections are not usable anymore, because there is so many of them. And there is no other option how to clear them then close plsqldeveloper and reopen it again, which I dont want to do when I have some work in it.
3 - it will be nice to have option to test all connections. During time I believe that I have some of them not usable, because database drop etc, but its hard to find which are ok and which not, so maybe some option to test all connections in one folder will be nice, with some result where it was wrong with option to delete them.
4 - it will be nice to have option to choose multiple connections when I want to add them from recent to folder. Or to have option to add them to folders directly from Connections window with mouse. Now I must click on one by one by right mouse button and choose Add to folder, then collapse all my folders one by one, then move it upper.. It really take a lots of time when I need to add more connections.
5 - sort by name. It will be nice to have option in edit window to sort and save item by name in that folder.
6 - in Define Connections it will be nice to have there not just standard folders, but Recent folder too, it will probably be more easier to add connections from that recent folder into my regular folders then to click on connections with right mouse button on one item, add it to folder, close Define connections, choose another database, click with right mouse button to edit connection...
Pavel
Pavel
