Connections pane
Maxmix
Hi!
I have disabled the "multiple connections" option, but have defined the whole "tree" of useful connections, like this:
1. There is small bug with background color of the main connection (the one formatted as bold), when the connections pane loses focus. The background remains dark blue.
2. I wonder, why am I presented with convenient connections tree at PSD launch, whereas at the reconnecting (Session|Log on) I see the old plain connect dialog?
Can you let me know your exact PL/SQL Developer version and your Windows version?
If you want to reuse a predefined connection or a recently used connection, use the Connection List. If you want to make a new connection that is not predefined and not in the history, use the Session > Log on function.
1. v.9.0.6.1666
Windows 7 32bit Enterprise, Classic color theme.
Previous version of PSD had the bug too.
Also, I have customized background color for Browser window.
Background isn't changing only for bold connection, and only in that window
2. Yes, I am doing this way. But maybe you can include new menuitem for the Connection List in Session menu, next to Log on? Because to reconnect now, one needs: A) open Connection List, B) double-click the desired connection string, C) close Connection List
