Connection pinning
Alex E
I'd really like to know how this "connection pinning" is supposed to work, I really don't get it?!? (maybe I'm just an idiot, but I really see no difference: sql window pinned or un-pinned)...
If I have 3 different, unpinned connections (sql window) and I'll change the main connection, all 3 unpinned connections should "follow", shouldn't they?! The connection status (left to the pin icon) doesn't change then -> why?!?
Someone please help: "pinned or unpinned"
Kind regards,
Alex
If the connection is not pinned (grey pin icon) the window will follow the main connection.
If the connection is pinned (red pinned down icon) the window will Keep its current connection.
Shouldn't the connection listed in the status line change when the main connection is changed? Mine never change, neither when the Pin is grey or red. It always stays with schema@originalconnection. How do I know if the connection has followed the main connection?
If the pin is grey, the connection on the status line of the window should indeed change if the main connection is changed. If this is not the case for you, can you send me some screenshots by e-mail to demonstrate the issue?
Update - I uninstalled plsdev (had a couple of versions, beta, etc.) and downloaded and installed the latest version again. Problem solved, the un-pinned connections now follow the main connection.
Thanks for your help!
