michaelbohler
I am running PL/SQL Developer version 9.0.4.1644.
I use the Connection Indicators defined as so:
sys@* - Green
system@* - Green
mbohler@* - Blue
*@* - Orange
Set toolbar indicator - checked
Set window indicator - checked
Set editor background color - checked
I am using Single session Session Mode.
Previously in version 8:
connect as sys or system
-> green editor screen
connect as mbohler
- > blue editor screen
connect as any other user
-> orange editor screen
Session / Log off
-> editor screen goes white
Now in version 9 the color does not go white (indicating that I have logged off), it stays the prior color of the user I was logged on as. Can I make this work as before or do you need to make a program change?
Thanks for your response.
sys@* - Green
system@* - Green
mbohler@* - Blue
*@* - Orange
connect as mbohler
Session / Log off
