debuggingIT
Using PL/SQL Developer 7.1.0.1337 with OCI version 8.1. Just running Windows 2004 SP4.
I have problems connecting to an Oracle database where PL/SQL Developer just hangs with no apparent error message. Is there a way to trouble shoot what the problem is? I notice similar problems in other posts but was unable to generate a log e.g."C:\Program Files\PLSQL Developer\plsqldev.exe" debugsql to perhaps shine some light on the problem.
I can connect to other oracle databases with the tool and I can use e.g. toad or command line to connect to the database I have problems with. I don't have the OS details but another machine on the same company network have also been able to connect to the db I have problems with.
No idea what the PL/SQL Developer startup sequence is actaully doing, can anyone advise on the best course of action to resolve my connection problem as it does seem local?
Cheers,
Cheers,
