Compiler-Hints: FUNCTION RETURN PIPELINED
Marc Bisping
PL/SQL-Developer Version 8.0.0.1480
As I define a pipelined-function
CREATE FUNCTION fct_test (...)
RETURN ...
PIPELINED IS
END fct_test;
to use it in a SELECT-Statement
SELECT .... FROM TABLE(fct_test(...));
the Compiler-Hint "Function '...' does not return a value"
is printed - but there is a return-value!
Can you fix it in the hints please?
