Compile Invalid Objects: not working correctly if current connection main connection
Bernhard S
I use PSD v9.0.1.1612
When I open "Compile Invalid Objects" it is first connected as main connection and works fine there. However if I change the connection at the bottom "change connection" selector to something different than the main connection it doesn't find any invalids any instead returns "No invalid objects found", even though there are invalid objects in this schema. When I connect to this other schema with main connection and do the same again, I get the invalids correctly returned.
I was having this problem recently then Marco pointed out it might be related to the object browser user or filter. I saw that mine was not set to the but to a user that had no rights. Thank you Marco!
