Compatibility of DOA 4.0.3 with Oracle 12c. I am using Delphi7
Is there a dependency of DOA 4.0.3 on Oracle 9 client? I have been using an exe built in Delphi 7 using DOA 4.0.3 in Windows Server 2008 with Oracle 9 client. When I tried to run the same exe on a different Windows Server 2008/2012 server, but with Oracle client 11g, it is not able to make connection. DB is tested from the new server and also the TNSNames verified.
Can you please provide your comments.
No, there are no dependencies. If the Oracle11g Client is configured correctly (you can check this with sqlplus.exe from the Oracle11g bin directory), your application should be able to connect as well.
If it doesn't work, please let me know the error message when connecting.
