Commnad Define
zolw
Hi all,
How can I use commande define in sql window?
It dosen't work from mi
Define v_product_id = "7"
select * from product where product_id = &v_product_id
The SQL Window does not support SQL*Plus commands, only SQL and PL/SQL. For SQL*Plus compatibility you can use the Command Window instead.
To use substitution variables in the SQL Window you can use the & symbol:
See chapter 12.3 in the User's Guide for more information about substitution variables.
