Commit button problem
We received your example by e-mail. I cannot reproduce this though.
thank you for the reply. I created the debug file, but I found it contains too much information that I cannot send (mainly connections' info). So just open new tab, create table by SQL, insert any line into it, close the all tabs and you will see that the Rollback button is active but doesn't work.
Thank you
