when I open a command window; and execute (Oracle 19c SE2 on Windows 10 64bit):
- Then clicking on the red Hand Symbol does not terminate the SQL immediately, but later then after few seconds
- Also the Hand does not change visually on Mouse -Down event
- The whole action gives you the impression that execution of command window is ins some way disconnected wiht the windows Header icons
2nd - Using the Statement Cache with and executing the same SQL again, the green execution triangle symbol (windows title embedded icons) stays for some seconds green, and after a few seconds it grays out and the hand icon gets red, Also in some way this feals disconnected...
so far
/Karl
SELECT * FROM DBA_OBJECTS;
so far
/Karl
