Command Window replacement variables?
jrow
How can I clear replacement variables in the command window?
In a command window do the following.
select '&repvar' from dual;
You will be prompted in a pop-up for 'repvar'.
If you run the select again, the pop-up will contain the last value entered.
If you do the following:
undefine repvar
When you run the select, the old value remains.
Yes, there is a need to clear it. When I run a script that has an UNDEFINE in it, the variable should become undefined.
I can't tell from one run to the next if/when the variables are established correctly or not.
Thanks - JR
i agree, there is a need to be able to clear it, but that will be coding fun since PLSD probably isn't getting the value from Oracle (it is a Window's popup where the user types in the value to use).
could you use a Test Window and ':' instead of '&'?
It is undefined after using UNDEFINE (you can check this by using define again).
When you are prompted later for the previously undefined variable, the old value is displayed again as a default for your convenience. There is no need to clear this temporary default value.
Marco,
But, I thought, that when prompted by PLSD for a value for the substitution, if there is a value in the PLSD pop-up window, clicking OK tells PLSD to pass that value to Oracle to use. Unless I clear the suggested value before clicking OK.
That is correct.
If you clear it, the substitution variable will be empty, and passed to Oracle as such.
