command window painfully slow with larger results
When i query large tables and i get many lines back, the command window is painfully slowing down, the more lines it has to display. If i use the sql window instead, this is a lot faster and doesn't slow down very much on larger results.
The problem with the sql window is, that i can't use real bind variables (:varname) there. The variables (&varname) in the sql window are replaced with the actual content before the statement is executed. It would be nice, if the sql window would also support bind variables.
If you need bind variables, you can use the Test Window. It supports result sets in the same way as the SQL Window.
Yes it does, but i can't export the result set from there. Binds in SQL Window would be nice, but what is really an issue is the performance of the command window. In version < 7 it was quite ok with larger results, but since 7.1 it is really slow.
